Sponsored by: CARiD
diff gears will they fit?
Old Apr 19, 2011 | 09:08 AM
924runnersr5's Avatar
i have 4.56 diff gears and want to put in 5.29s..will they fit in my axle housing?
Old Apr 19, 2011 | 09:11 AM
crash121's Avatar
Sure, as long as you get the ones specifically for the diffs your running.
Old Apr 19, 2011 | 09:19 AM
well im trading my stock gears with a man who has the 5.29s...we are swaping out the whole 3rd members i have a 92 and his is i believe a 95....how do i know for sure they will work like what do i have to match up?
Old Apr 19, 2011 | 10:52 AM
kiyobrown's Avatar
If the gears are already setup in a housing and you guys are swapping whole thirds, then you will be fine.
Click link in my sig.
I would at least check the gear mesh pattern before throwing them in your rig, If they were not set up properly it won't last long.
Old Apr 19, 2011 | 11:04 AM
Fink's Avatar
A few minutes searching on this should yield a TON of threads about it, also.
Fink
Old Apr 19, 2011 | 12:52 PM
blake.nemitz's Avatar
yep drop em in i run 5.29's with no clearance issues. and as stated above look at the contact pattern if it is crappy i would pass if they were ran a while that way
Old Apr 19, 2011 | 01:06 PM
is it any diffrent if they have lockers in them?? or is it still the same size?
Old Apr 19, 2011 | 01:14 PM
no same size just a different carrier is all. most toy thirds are interchangeable even the elocker with a slight mod. the only one that wont fit is the bigger land cruiser diffs 9inchers i think and the new taco 8.4. a plain third with a locker and 5.29's will fit in there and you are getting a bargain if he is trading you straight up
Old Apr 19, 2011 | 03:34 PM
yupp and it is such a good deal!!!
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
jaretstuff
Aug 4, 2015 02:08 PM
scottyg486
Jul 19, 2015 05:34 PM
wilbertd
Jul 6, 2015 07:39 AM
