Detroit locker for DD?
I drive mine with 37s and a detroit rear, and its not bad, just have to watch throttle inputs, she'll spin em specially when wet, not so much when dry!! Mine hardly ever unlocks (when it does it will scare the crap out of you cause its loud untill it wears a little bit), the only reason I know its back there is hearing the tires scrub when turning, I actually want to put on in my DD/tow rig dodge diesel!!!
That being said, if it snows where you live (it doesnt snow here and has only snowed once here since I have been alive), it may not be good for you, because like I said, when its wet it will want to power slide! I have boggers and that doesnt help, she'll get sideways when in neutral...lol!!
#27
well if I do SAS it wont be for a while, I just wanna get a locker, some new wheels and maybe some bumpers, then I'll just wheel it like that until something breaks, or I get bored with it.
#29
Anyone have any experience with a "Powertrax No-Slip Traction Systems". Still havent decided what im going to do yet, and this seems like it could be an option.
http://www.summitracing.com/parts/PW...1/?image=large
#31
I'm in agreement with Mudpig, do the Aussie in the rear, but only the rear.
A rear locker makes as much difference with traction as 4wd does over 2wd. A front locker only makes a difference in hardcore 4wheeling, so don't waste your money until you do the SAS.
A locked rear and open front has little effect on causing under-steer (although it can cause "some" under-steer). But once the front is locked, the front just wants to plow straight. Yet another reason not to lock the front until you get hardcore. (BTW, a hardcore 4wheeler doesn't care about under-steer because you can always back up and 3pt turn, but you can't always get the front to climb without a locker.) Also, with a daily driver, you'll want to use 4wd on the highway when the roads are bad; which is not the time for a front locker causing under-steer.
You can do the Aussie or LockRight install yourself, whereas any other locker/limited slip replaces the carrier and requires resetting up the gears. If you pay a shop to do the carrier install, the labor will be more than the cost of the Aussie or LockRight.
"When" you re-gear, lose the Aussie and install the smoother Detroit Soft Locker. You can sell the Aussie and recover some of the cost; although you are still money ahead for the reason stated above.
By the way, for reference of my point of view, my daily wintertime commute is up and down iced over narrow (two track) steep (20% grade) mountain ranch roads. "Theoretically" I'm supposed to use chains, but my wife and I are too lazy, so we just 4wheel until we slide off the road, then put on the chains. Of course, only one side of the rig is accessible at that point, but with lockers, that's no problem and enough to get unstuck. All of my rigs eventually get rear lockers: LockRight in the 4Runner (until I re-gear) and Detroits in everything else. For the periods when I have some rigs with lockers and one without (like right now), I don't change my driving habits at all, but I do find that the open and limited slip rigs really struggle on the ice... So much so, that's why I install the lockers just as soon as I can afford them.
#32
Awesome, thanks for the info. I'm currently trying to track down some stock 4.88s and then I'll go from there. By the sounds of it I'm better off regearing and locking at the same time. Now I just have to make sure I don't wanna run 35s in the future lol. Whoever said wheeling was expensive was ablsolutely right!
#35
Well I finally got a locker. Went with an aussie for the rear, and replaced the lift blocks i had back there with new leafs.
Now i just have to replace all my balljoints, and an axle up front and I can get back to beating on her.
I know its been a while, but thanks for helping me on making a decision everyone.
TheBFA
02-15-2020 06:55 AM
1uzRunner
63
11-10-2018 03:58 PM
83yotastockR
11
11-10-2015 06:54 AM
Toys4parts
09-26-2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
