Can i fit 265/75/16 without cutting and rubbing?
Old 04-28-2006, 07:17 PM
DeckerT4R's Avatar
I just got my first car, 98 4runner sr5, 4x4, 5 speed, its got the 265/70/16's.
My tires however will need to be replaced soon. I was wondering if a 75 series tire would fit without a lift. Also my speedo is off by 7mph regularly according to my TomTom GPS, where can i get a something to correct my speedo.
Thanks,
Ben
Old 04-28-2006, 07:30 PM
ebelen1's Avatar
Thanks,
Ben
Please search. Your first post was the deckplate mod and now you want to know if 265/76/16's will fit. Please search but the answer is they will fit w/ no issues.
Old 04-28-2006, 07:33 PM
DrBeau's Avatar
Couple questions:
Tires: Have you searched? I know you have done some searching before from the other thread you posted.
Speed: Which direction is it off? The only true way to fix this is to regear, but this isn't really a viable option. The other option is an electronic a la here. I don't think this is a good idea, as it only changes the speedo and not the odometer/trip meter.
Old 04-28-2006, 07:40 PM
GSGALLANT's Avatar
Your 265/75/16's should fit fine. My speedo is closer to actual speed now that I've increased my tire size from 265/70/16 to 265/75/16. You might find that the size increase will get yours closer also. In which direction is your speedo currently off? (reading higher or lower than it should?)
Old 04-28-2006, 07:46 PM
DeckerT4R's Avatar
First off thank you for a civil answer to my question. My speedo is saying i am traveling slower than i actually am. Around 7MPH off.
Old 04-28-2006, 07:49 PM
DrBeau's Avatar
First off thank you for a civil awnser to my question. My speedo is saying i am traveling slower than i actually am. Around 7MPH off.
If I understand what your saying, when you're speedo says 60mph you're actually traveling at 67, correct? If that's the case, getting bigger tires will just make the problem worse.
Old 04-28-2006, 07:50 PM
rimpainter.com's Avatar
My 265/75/16's Pirelli Scorpians rubbed until I got a 1" body lift.
Old 04-28-2006, 07:52 PM
DeckerT4R's Avatar
Yes you are correct.
Old 04-30-2006, 12:29 PM
LSUMatt1514's Avatar
They'll fit....but I'm still not convinced that they aren't the cause of my vibration problem. I never had vibration problems when I had 265/70/16s but every set of 75s has given me pretty strong vibration above 65+ mph.
Matt
Old 04-30-2006, 01:30 PM
msw0085's Avatar
I had that tire in the 15" diameter on my 2wd 4runner but never had any problems with rubbing
Old 04-30-2006, 03:27 PM
DrBeau's Avatar
The 265/75/15 is an inch smaller. The metic sizes are based on sidewall height instead of overall diameter.
Old 04-30-2006, 07:16 PM
hupptoy's Avatar
Sounds like you have a tire balance issue. Where do you have your tires balanced, and do they have the proper adapter for lug-centric wheels? You shouldn't have vibration problems with this size unless they aren't balanced properly.
hupptoy
Old 04-30-2006, 07:37 PM
hupptoy
He's covered that and more. Check out this thread:
https://www.yotatech.com/forums/show...ight=vibration
JHupp's Avatar
as stated, they will fit no problem. I wouldnt worry about a power loss, I have the v6 auto, and I never noticed a power loss when changing to a 265/75 from a 265/70. The mpgs went down a little, even though the odo is off, but I thinks its from the tread of an AT rather then the stock dunlops.
Old 04-30-2006, 07:41 PM
DeckerT4R's Avatar
Matt
Is what he said here a common problem because i regularly travel at 85-90MPH and i dont want insane vibrations? I can live with some but "pretty strong vibration".
Old 04-30-2006, 07:44 PM
garrett1478's Avatar
no, it's not common.
Old 04-30-2006, 07:55 PM
Bob_98SR5's Avatar
ben,
check your PM. moved to newbie section
bob
ghostmoney
08-06-2015 08:40 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: Can i fit 265/75/16 without cutting and rubbing?
