brake problem
brake problem
currently having some brake problems and would appreciate some assistance. I ordered new pads for my 22re 1989 4runner, and noticed the pads i purchased (mkd410) are to big for the caliper. i compared the pads i bought to the pads on the runner, and the pins are spread further apart and shims are not wide enough to fit. the caliper says s12+8 on the side, and after some reading noticed that it could be for an older toyota truck. i searched from 1983 trucks as well as the 1984-88 4runner v6/22re and they all come up with the same brake pad part number. please help!
Sounds like you have the correct calipers for your 4cyl truck. One small piston and one large piston on each side of the caliper. But it sounds like maybe they gave you V6 caliper pads. (For vehicles equipped with the V6). Those calipers have four larger pistons in each caliper. (also a popular upgrade for 4cyl trucks, do a search if you've not heard of it.).
Maybe exchange the pads for '86-'87 pickup era? No V6 was available then so maybe the parts person will have less options. Just a thought anyway...
heres a picture of the new pad under the old pad. the old pad is offset to the right so you can see the hole lined up, and you can see that the new pad is longer and the pins do not line up. part number for the new pad is MKD410
after some more research this is what comes up. fyi it is a vented rotor
TOYOTA TRUCK
8173/8174 95 ALL S12WE
4 Runner
8171/8172 95-91 ALL S13WB
8169/8170 91-88 ALL S12W R/L
4407/4408 87-84 ALL (4 Cyl) S12-8
Landcruiser
1478/1479 92-91 ALL S13WA
4407/4408 90-75 ALL S12-8
TOYOTA TRUCK
Pickup, Hi-Lux
8171/8172 95-91 T100 Pickup 4WD 1/2 Ton S13WB
2011/2012 95-89 2WD 4 Cyl. l 17S R/L
1242/1243 95-89 DRW AISIN 1 R/L
8567/8568 91-89 Long Bed F18Q R/L
514/515 91-8/83 2WD, 1/2 Ton AISIN
4407/4408 88-86 Long Bed 4WD W/4 Cyl. S12-8
4409/4410 85-80 Long Bed 4WD S12+8
and this post says
Front
1996-2001 W/ 16” Wheels............................................ ............ S13WM 1830 1831
1996-2001 W/ 15” Wheels............................................ ............. S12WE 1828 1829
1992-1995 .................................................. ............................ S13WB 1601 1600
1989-1991 From 4/89................................................ .................. S12W 1241 1240
1988-1989 W/ 4 Cyl. Before 4/89................................................ . S12+8 827 826
1988-1989 W/ 6 Cyl. Before 4/89................................................ . S12W 1241 1240
1986-1987 Vented Rotor............................................. ................ S12+8 827 826
1984-1985 Solid Rotor............................................. ................... S12+8 821 820
TOYOTA TRUCK
4 Runner
Landcruiser
TOYOTA TRUCK
Pickup, Hi-Lux
and this post says
Front
jasonty
41
12-23-2018 01:00 PM
skoti89
09-11-2015 07:46 AM
Johntom240
7
07-13-2015 12:18 AM
Jnkml
07-06-2015 01:20 PM
