Body swap: 81 truck on to 99 Tacoma frame
Old 09-05-2011, 02:59 PM
81PILE's Avatar
I rolled my 99 Tacoma this weekend, now I am thinking of swapping my 81 Toyota truck body on to the 99 Tacoma frame. Looking for advise on if the swap is even possible. Any advise or knowledge would be appreciate.
81pile
Old 09-05-2011, 03:12 PM
xxxtreme22r's Avatar
anything is possible with enough welding skill, metal and cutting torches.
Old 09-05-2011, 03:18 PM
scuba's Avatar
If irbis Offroad can put first gen 4Runner bodies on 3rd gen 4Runner frames then your idea has to be possible.
Old 09-05-2011, 03:20 PM
87 Deathtrap's Avatar
If you do it, start a build thread please. That's something I would like to see!
Old 09-05-2011, 03:24 PM
SCToy's Avatar
Scribed, I'm super interested in doing a similar swap. 81->95 P/U frame. Mine should be more straight forward though.
Old 09-06-2011, 12:06 AM
wyoming9's Avatar
Smile
Your just swapping the bed ???
The Cab also??
The bed measure where the bed mounts to the frame move mounts to all line up . You might need to make your own brackets for the back of the bed.
You would need to make sure your fuel fill neck is the same place or decide how to fix it when it isn`t
Lights make up or rewire the plugs you have
Easy but labor intensive !!!
Old 09-06-2011, 12:17 AM
wyoming9's Avatar
Smile
If your also doing The Cab it can be done
be like a engine swap but backwards you have the engine so your interfacing the engine harness to the cab harness.
Hard call to make either way lots of work. Lots of fabricating I am thinking alot of trail and error try this try that
The whole front end attaching points are so different
To have to pay someone you could replace your Tacoma.
How bad is yours?? might be a whole lot easier to repair that one.
Old 09-06-2011, 12:57 AM
Fossilized
Staff
dropzone's Avatar
It would be a very labor intensive swap.
Seeing an IFS 1st Gen almost seems like sacrilege.
Go for it. And post lots of pics:Bigok:
Old 09-06-2011, 05:17 AM
SCToy's Avatar
Seeing a total chaos long travel first gen would be friggin awesome though
6th Gear
19
12-10-2019 07:31 AM
duckhead
170
11-13-2017 06:07 AM
vasinvictor
01-20-2016 12:39 PM
merc1100sc
06-26-2015 05:24 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
Quick Reply: Body swap: 81 truck on to 99 Tacoma frame
