Automatic transmission
Old 06-13-2010, 07:49 PM
jamz316's Avatar
I have a 86 Toyota pickup and at times when I come to a stop, the trans won't down shift. When that happens, I have to put it in 1st. Can anyone help?
Old 06-13-2010, 07:52 PM
PismoJoe's Avatar
Dirty fluid, bad solenoids, contaminants in the valve body, bad transmission.....
I would research some of these issues, there are some good write ups on here
Old 06-13-2010, 09:19 PM
jamz316's Avatar
Thanks, I will check them out. Any other suggestions on which solenoids?
Old 11-08-2010, 10:30 AM
cliftymike's Avatar
Question 86 22R auto tranny will shift into 1st, 2nd...not drive.
Just put new head gasket on my 86 2wd 22R. I put it in drive (has OD button) and take off. Shifts into 2nd fine.......will not shift to drive. Acts like a vacuum problem, as it was fine 2 days ago when I pulled it apart.......not so much now. Have tried several diagrams, none are exactly like mine as I bought it 4 years ago with already 120,000 on it. I have all vacuum lines hooked up and doesn't appear to be any leaks. Am lost for ideas now..........fluid is fine.
4x4-runner
12-27-2016 01:58 PM
BeMiceElf
10-10-2015 09:40 PM
eggens
09-05-2015 12:16 AM
kelly1450
09-02-2015 12:29 PM
Hugh_Mann
08-31-2015 04:02 AM
Quick Reply: Automatic transmission
