87 4runner won't start
I was getting a check engine light on my 87 4runner. I did the paper clip trick and found that I needed to replace my o2 sensor. I replaced the o2 sensor, and started it up. Well I forgot that the paper clip was still in the diag port, and turned off the car right when I realized that. When I tried to start it again it wouldn't start. In fact, it loses all electrical power after trying to start it(it click's once, then loses power). I then have to wait about 5-10 mins for the electricity to come back. I've checked all the fuses, took the relays out and banged them around a bit to make sure they were not stuck. I'm not sure what to try next, haven't been able to find someone else with this issue. Any help is greatly appreciated! Thanks
Yeah...I work at a car dealership in the shop and I have had a few cars lose all power while they're on my rack and do the same thing. So I jump em and let em run for a while to recharge the battery.
But yeah sounds like a battery to me....it is possible for them to take a crap out of no where.
Staff
Sounds like you are a little worried about starting it with the paperclip in, if I am understanding you right? You didnt do any damage with the clip in, it is how you set the timing.
Dont see where you are from, but with the heat in some parts of the country it is very possible your battery is toast.
Id check your battery cables. The battery might be fine it sounds like you have a bad ground. Clean the battery terminals and try again. it can happen suddenly like that and its just a coincidence that it happened while you were working on something else.
aciorba23
06-29-2015 04:18 PM
