4Runner just quit
4Runner just quit
i have a toyota 4runner and it just quit on me it was working fine one day and the next day it stopped. it turns over and im getting fuel and fire to the plugs. What could be the problem?
it has a normal sound like its trying to start but nothing gets it going at first i thought it was the fuel pump so i screwed the fuel line off to see if gas was coming through and it was then i checked all the plugs to see if they had fire going to them and they do...I find it weird for it to work one day and quit the next.
sounds like desertcamper is referring to the timing belt and its possible demise.....
year, engine, miles might be helpful too.
so just out of curiosity i turned the ignition and it started right up so i shut it off and tried again and back to the same problem...could it be that im getting to much fuel
Well, there's only 3 things needed for an engine to run:
- fuel
- air/compression
- spark
It sounds like you've verified spark and fuel to the rail. Do you know if the injectors are firing and you're getting fuel in the cylinder?
Compression test?
- fuel
- air/compression
- spark
Compression test?
no compression test yet. im not sure if the injectors are getting fuel to the cylinder, but it was running fine one day and the next it just quits.. i tried some starter fluid into one of the cylinders and still nothing. i guess im going to have to do the compression test before i can decide on what im going to do with this thing
Well, when you figure out which of the three is not happening, it's a lot easier to trace it down.
Check your fuses, the EFI fuse in particular - especially if you DON'T have a CEL, or any stored codes. Here's how you check for codes:
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
well i got it going...seems the timing belt jumped time...the spring on the tension pulley busted so i replaced it with one from the local salvage yard 5 bucks..looks like im back on the road again....thanks for the info.
Thanks for the update!
BeMiceElf
10-10-2015 09:40 PM
