Sponsored by: CARiD
4Runner just quit
Old Sep 4, 2009 | 09:38 PM
lostINtheSAUCE's Avatar
Exclamation 4Runner just quit
i have a toyota 4runner and it just quit on me it was working fine one day and the next day it stopped. it turns over and im getting fuel and fire to the plugs. What could be the problem?
Old Sep 4, 2009 | 10:29 PM
desertcamper67's Avatar
Does it sound normal when turning over or does it sound faster or higher pitched?
Old Sep 4, 2009 | 10:42 PM
it has a normal sound like its trying to start but nothing gets it going at first i thought it was the fuel pump so i screwed the fuel line off to see if gas was coming through and it was then i checked all the plugs to see if they had fire going to them and they do...I find it weird for it to work one day and quit the next.
Old Sep 5, 2009 | 07:04 AM
habanero's Avatar
sounds like desertcamper is referring to the timing belt and its possible demise.....
year, engine, miles might be helpful too.
Old Sep 7, 2009 | 04:54 PM
alright so i tore it all apart and the belt is in good condition any other ideas
Old Sep 7, 2009 | 05:23 PM
so just out of curiosity i turned the ignition and it started right up so i shut it off and tried again and back to the same problem...could it be that im getting to much fuel
Old Sep 7, 2009 | 06:09 PM
tc's Avatar
tc
Year and engine?
Old Sep 7, 2009 | 06:13 PM
1990 3vz
Old Sep 7, 2009 | 06:16 PM
tc's Avatar
tc
Well, there's only 3 things needed for an engine to run:
- fuel
- air/compression
- spark
It sounds like you've verified spark and fuel to the rail. Do you know if the injectors are firing and you're getting fuel in the cylinder?
Compression test?
Old Sep 7, 2009 | 06:23 PM
no compression test yet. im not sure if the injectors are getting fuel to the cylinder, but it was running fine one day and the next it just quits.. i tried some starter fluid into one of the cylinders and still nothing. i guess im going to have to do the compression test before i can decide on what im going to do with this thing
Old Sep 7, 2009 | 07:47 PM
tc's Avatar
tc
Well, when you figure out which of the three is not happening, it's a lot easier to trace it down.
Check your fuses, the EFI fuse in particular - especially if you DON'T have a CEL, or any stored codes. Here's how you check for codes:
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
Old Sep 9, 2009 | 10:22 PM
well i got it going...seems the timing belt jumped time...the spring on the tension pulley busted so i replaced it with one from the local salvage yard 5 bucks..looks like im back on the road again....thanks for the info.
Old Sep 10, 2009 | 01:10 PM
tc's Avatar
tc
Congrats!
Old Sep 10, 2009 | 02:57 PM
habanero's Avatar
Thanks for the update!
bigjstang
Jun 2, 2025 03:56 PM
BeMiceElf
Oct 10, 2015 09:40 PM
thefishguy77
Jul 30, 2015 10:59 AM
87blyota
Jul 10, 2015 04:31 AM
Nickdigg
Jul 7, 2015 06:04 AM
