4Runner 95 Diesel 3L Motor Power Steering Issue - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-23-2009, 05:18 PM   #1 (permalink)
Hi Guys
Im a newbie here with little knowledge about cars and I looking for your advice.
I have a 1995 4Runner Diesel 3L Motor with a power steering issue, at the beginning I felt the power steering was working at half capacity because the steering wheel wasnt returning to its place by itself after turning.
Then I heard a humming / moaning noise while turning left and more recently a squealing noise when the steering wheel (that also have a play issue) turns until the end of its capacity
I was told to replace idler and pitman arms, which I did.
However problem continued, I suspected about the power steering pump, so I purchased one at ebay and a new belt from our local toyota dealer but after removing the original pump, we found I got it wrong and haven't been able to find the correct one.
So we decided to put all back together and now, the problem is worst, there is no power steering at all, and there is a moaning noise just turning a little the steering wheel instead of until the end like before.
Any advice ?
L0RDF3NRIS is offline
Old 10-23-2009, 07:40 PM   #2 (permalink)
tc
tc's Avatar
Sound slike your pump is bad.
Lemme guess - did you fill it with power steering fluid? (It takes ATF)
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 10-23-2009, 09:12 PM   #3 (permalink)
Power Steering Fluid (generic)
Old 10-23-2009, 09:19 PM   #4 (permalink)
ok so I just need to drain the power steering fluid and fill it with ATF to fix it ?
or this could cause a severe permanent damage on my car ?
just to go and complain with the guy who did this
Old 10-24-2009, 09:58 AM   #5 (permalink)
tc
tc's Avatar
In my experience, using PSF instead of ATF spells quick death for the power steering pump.
__________________
tc is offline
Old 10-24-2009, 10:34 AM   #6 (permalink)
bigt's Avatar
my hiluxm has started in nuetral at first or when going slow the steering gets real tight..
i think its just my belt as the fluid is still full.. its not like the alt where there is a bolt to put tension on it.. i read in my manual i have to loosen both bolts then PRY the pump while someone else tightens those bolts..
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
current build
1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/
bigt is offline
Old 10-24-2009, 11:53 AM   #7 (permalink)
tc
tc's Avatar
Usually (not always), you can hear the belt slipping if that is the problem.
__________________
tc is offline
Old 10-25-2009, 12:49 PM   #8 (permalink)
bigt's Avatar
yeah it sounds likea belt slipping but the tires are really hard to move!!!
so ill have to find someone to tighten while i pry i guess.. ill go check out the situation.. thanks
__________________
current build
bigt is offline
Old 10-25-2009, 02:24 PM   #9 (permalink)
bigt's Avatar
ok so i was having a hella of a time finding the power steering pump..
BECAUSE IT WAS ON THE OTHER SIDE being right hand drive.. wow i feel so stupid well the belt is reallly really loose...
i dont have anyone to help me tonight would it be ok to drive 10km to work tommorow or will it sherd the belt?
__________________
current build
bigt is offline
Tags
3l, 4runner, 95, add, diesel, fluid, noise, power, pump, removalsurf, runner, squealing, steering, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
