22re, trouble firing up
Old 12-12-2008, 10:30 AM
GOSHRED005's Avatar
I have an 88' 4runner with the 22re motor in it, and i'm having problems starting it. When I turn the key, the motor tries to start, but never turns over. I do smell gas coming out of the exhaust so i'm pretty sure its nothing to do with the fuel. I've noticed some "spitting, studdering" before she went down, and when i checked the plugs and wires, plug #4 was soaked with gas. So, i'm thinking its the plug wires or the distributor. Is that a reasonable possibility? What do you think might have happened? Plz reply! Thanks
Old 12-12-2008, 12:14 PM
okie81's Avatar
My old toyota got some water up under the distributor cap and threw the spark around under there causing a lot of sputtering and hard starts. It was fine after I got the water out. Good luck.
Old 12-12-2008, 12:17 PM
rdlsz24's Avatar
What is the temperature where you live?
Rob
Old 12-15-2008, 04:05 PM
GOSHRED005's Avatar
srry guys, been really busy, and thanks for ur replies. So i dried out the distributor cap, and, Viola!
I do live in Hawaii, so it does rain more than usual, especially now, during the winter seasons. So, is there a way to seal the cap to lessen the chance of moisture getting in?
Old 12-16-2008, 06:55 PM
crombieposterboy's Avatar
I do alot of off roading and I use instant silacone gasket maker around the cap. It does the job for me,
Old 12-16-2008, 09:04 PM
scuba's Avatar
Also known as FIPG (Form in place gasket) Or RTV...
Just a heads up...
Old 12-17-2008, 01:41 AM
GOSHRED005's Avatar
awesome, i'll try it out, thanks guys
Doug4320
03-24-2018 10:11 PM
mskalmus
05-28-2017 07:51 AM
256mbaker
07-31-2015 06:45 PM
Sandman
07-14-2015 12:36 PM
ZONAYODA
07-13-2015 07:17 PM
Quick Reply: 22re, trouble firing up
