22r doesnt wanna stay running when warm - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2009, 02:53 PM   #1 (permalink)
vcamelli's Avatar
ok we've searched and tinkered and searched and tinkered... now were stumped. We own a 1984 pickup with the 22r. the problem is this... it will start and idle quite well... but as soon as it gets any sort of warmth to the motor it dies. it will start back up and run as long as you have your foot on the gas. but as soon as you take your foot of the throttle it chugs and dies. so far we've replaced the intake manifold, carb (replaced with stock aisin), and the fuel pump with no real effect. we've adjusted the carb to run lean... and adjusted it to run rich. ive tried messing with the distributor. we've changed sparks, wires, and fuel filter.... still nothing. So my question to you is.... WHATS WRONG WITH THE YOTA? any advice is awesome at this point. Were moving back to utah from new york in a month and need this thing to do it. thank you!
vcamelli is offline
Old 10-25-2009, 02:55 PM   #2 (permalink)
Adh007's Avatar
Replaced all your vaccuum lines?
__________________
- Adam Hart
1993 Pickup
Adh007 is offline
Old 10-25-2009, 02:57 PM   #3 (permalink)
vcamelli's Avatar
all that were damaged.
vcamelli is offline
Old 10-27-2009, 03:10 PM   #4 (permalink)
I just rebuilt my 22 RE and had the same thing. When it would reach the temperature for the thermostat to open (warmed up) it would cough sputter and quit. I found a water line going into a vaccuum port, which I realize was MY fault, but when I got the lines straightened out, it ran great.
I think you should consider the possibility of water getting into your intake somehow. Maybe head gasket? I don't know, just trying to throw out ideas.
gaines808 is offline
Old 10-27-2009, 03:57 PM   #5 (permalink)
83
83's Avatar
Not sure he'd run into that with the 22R, but that's a real good thought. How about the choke? Maybe your idle speed is set so low, that once it drops down from fast (cold) idle, it's stalling since it's set too low. Where in NY to where in UT? I've lived both places.
Doesn't seem like a timing issue, but...worth checking.
__________________
Zach
'83 Shortbed 4x4
L52HD
Rebuilt & Mostly Stock
83 is offline
Old 10-27-2009, 09:29 PM   #6 (permalink)
vcamelli's Avatar
Sandy. We've tried adjusting the idle but no real difference. If it helps at all the problem showed up while downshifting. We considered a warpped manifold because we sprayed starting fluid by the gasket and it revved high. After changing it out it fixed that problem. But the whole dying issue remains. It will stay running while driving as long as there is back pressure. I'm stumped.
vcamelli is offline
Old 10-27-2009, 09:54 PM   #7 (permalink)
A gas line too close to something hot? carb wants gasoline in liquid form. if it gets too warm it'll be partial vapor. Just a thought.
__________________
1994 Toyota Pickup 4WD
Reg Cab 22RE 5spd
107K and running strong...but needs work.
Nogarage is offline
Old 10-27-2009, 10:04 PM   #8 (permalink)
vcamelli's Avatar
Fuel bowl has gas in it. Could it be a bad cat?
vcamelli is offline
Old 10-27-2009, 10:20 PM   #9 (permalink)
22RUCRAZY's Avatar
cats act better the hotter they get , i say double check vac hoses and your choke mechanism good luck
22RUCRAZY is offline
Old 10-28-2009, 08:01 AM   #10 (permalink)
vcamelli's Avatar
Double checked and then checked again on vacuum lines. What about this vacuum switch next to the vsv any way to test these? And what do they do?
vcamelli is offline
Old 10-28-2009, 08:18 AM   #11 (permalink)
seanmearse's Avatar
Quote:
My buddy jonnyboy on here just bought an 83, ran like crap, dying, sputtering, sometimes a high rev, he pulled the cat off and it runs great. Its a possibility. Take it out of the equasion and see what happens.
__________________
The Internet, where men are men, women are men, and children are FBI agents.
Proud sponsor of the re-poster thread.
http://www.yotatech.com/f5/you-re-poster-193103/
84 SR5 pickup, Mostly stock 22R, K&N air filter, Mobil 1 oil filter, Cherry Bomb, Mobil 1 engine, Royal Purple diff and trans fluid, 15X8 street locks, 3 inch procomp front springs, waiting to buy rears, rancho RS9000XL's up front.
2003 Vstar 650, straight pipe, loud and fast baby!
seanmearse is offline
Old 10-28-2009, 09:03 PM   #12 (permalink)
vcamelli's Avatar
Not the cat. Wtf is wrong with yoda
vcamelli is offline
Old 10-29-2009, 06:21 AM   #13 (permalink)
83
83's Avatar
I dunno. Hard to say over here if you've missed something in the things you've already gone over. How's your coil? No cracks or anything?
__________________
Zach
'83 Shortbed 4x4
L52HD
83 is offline
Old 10-29-2009, 02:30 PM   #14 (permalink)
vcamelli's Avatar
Checked gas for water nothing. Oil was fine too. Checked the vacuum switch and it seems like its shot. Looking for one is a pain. No Toyota dealership has one from Boston to la. any good websites for replacement parts? Help!
vcamelli is offline
Old 10-31-2009, 10:35 PM   #15 (permalink)
toyotabull's Avatar
remove your breather and look into the carb and see if when you pump the trottle cable you can see fuel squirt in the carb. Good luck
__________________
85 toyota rancho lift
33 in tires on 15X8 steel
270 lift cam and flat tops
Those who do not learn from history are doomed to repeat it, or they're showing up their friends. Again!
toyotabull is offline
Old 11-02-2009, 04:22 PM   #16 (permalink)
vcamelli's Avatar
Checked compression... Nada... It keeps coming back to this vacuum switch. I pulled the switch and plugged the line to it. The truck ran the same. The switch leads to the fuel cut off selenoid... Anyone dealt with this?
vcamelli is offline
Old 11-03-2009, 06:27 AM   #17 (permalink)
83
83's Avatar
http://www.toyotanation.com/forum/ar.../t-275556.html
__________________
Zach
'83 Shortbed 4x4
L52HD
83 is offline
Tags
1993, 22r, 82, bad, buy, idle, lean, pickup, rich, running, runs, stay, switch, toyota, vacuum, warm
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
