22r Distributor Vacuum Advance
Old 02-07-2010, 03:49 PM
ToyotaLee's Avatar
I have an 86 Toyota Pickup 22r. I'm trying to find out how to diagnose the distributor vacuum advance to find out if it needs to be replaced or not. I tested both tubes with vacuum. The one closest to the distributor will hold vacuum but slowly lose vacuum. The one further away from the distributor will not hold any vacuum at all. Does this mean that the vacuum advance diaphragm is bad?
Old 02-07-2010, 04:53 PM
myyota's Avatar
Your vacuum advance unit is bad, both sides should hold vacuum. I had to replace the vacuum advance unit on a truck i owned a few years ago, and the only place i could find one at was the dealer, and it cost me 200.00 dollars (no joke), you can buy a complete new distributor for less than that.
Old 02-07-2010, 04:59 PM
ToyotaLee's Avatar
That makes sense, I knew this was going to mean "expensive."
Old 02-07-2010, 05:04 PM
myyota's Avatar
Yea man, you wouldn`t think that part would be so expensive, maybe 50-60 dollars tops, but i had to have it. It wasn`t until later that i realized that i could have got a complete new distributor for alot less.
Old 09-24-2010, 06:25 AM
fooey's Avatar
ok so i'm having the same problem. where are you finding new (not rebuilt) toyota distributors for cheap?
Old 09-24-2010, 07:33 AM
myyota's Avatar
Check out www.rockauto.com or www.partstrain.com
Blamalam
03-12-2022 07:34 AM
sandyota
02-04-2021 11:16 AM
cars-guy
08-16-2020 06:59 AM
raptor510
02-17-2017 07:11 AM
raptor510
08-19-2015 02:15 PM
Quick Reply: 22r Distributor Vacuum Advance
