2" BL really worth it? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-10-2008, 11:16 PM   #1 (permalink)
hey guys. I've been hearing lots of talk about how getting a 2" BL on my 3rd gen runner is a waste. I wont be taking it off road much at all, but I want to sit higher, and I think it looks good anyways. Is it as dangerous as everyone puts it out to be? I mean if a BL is cheap, then how is it a waste? If I do decide to put one on, what else do I need to look for as far as mods go? thanks alot.
guitarplayer360 is offline
Old 02-11-2008, 07:56 AM   #2 (permalink)
Robert m's Avatar
if you dont go off road much and want to be a little higher, then do the body lift. like you said its cheap, and they are pretty easy to install. i did the 2'' on my truck in less then 4 hours from start to finish. they get a bad rap from people that dont like them because they are not "true lifts" or because they think they are unsafe. as long as the body mount bolts are tight then there is nothing to worry about. get the kit from 4crawler and you will be happy with it.
__________________
94 pickup: Std Cab, 22RE, 5spd, 2wd
Front: Total Chaos Uniball Kit, Downey Torsions, Fox 2.0 8'' Reservoir Shocks, Hannemann Fiberglass Fenders
Rear: Deaver F55 Leaf Springs, 9'' Total Chaos Shackles, Fox 2.0 14'' Reservoir Shocks, Custom Bed Cage, 4:10 gears & LSD
30x9.5 BFG AT Tires
Robert m is offline
Old 02-11-2008, 08:37 AM   #3 (permalink)
Yodaforce's Avatar
BL's are usually used only to gain a little more for tire clearance. Sure the body will sit a little higher, but the frame gets a little ugly sticking out underneath.
__________________
"Diverse-Customs" Hot Rods, Street Rods, Custom audio and video installation, sheet metal fabrication, tube work, bumpers, lift kits, just about any kind of custom work imaginable!
Visit us at Diverse-Customs.com
Yodaforce is offline
Old 02-11-2008, 08:54 AM   #4 (permalink)
AxleIke's Avatar
Only reason not to do a body lift is because you don't like the look. If you are fine with the look, then by all means. Nothing wrong with it.
As for offroading, thats got nothing to do with it. Lots of hardcore guys running 1 and 2 inch body lifts.
Other mods you may need once you've put the BL on would be a short throw shifter for the transfer case. Not guaranteed, but its possible.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction
-Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail.
-Internet Nice Guy
AxleIke is offline
Old 02-11-2008, 09:36 AM   #5 (permalink)
what about steering extensions? Also, will I have problems with my front bumper? I have a 98 4runner.
Old 02-11-2008, 09:43 AM   #6 (permalink)
4Crawler's Avatar
Brackets/extensions are available for bumpers and steering, etc:
- http://www.4crawler.com/4x4/ForSale/...shtml#GenIII.2
Installation notes available on-line as well:
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 02-11-2008, 10:32 AM   #7 (permalink)
Yodaforce's Avatar
A quality BL will include everything except for rear bumper brackets.
__________________
Old 02-11-2008, 11:09 AM   #8 (permalink)
tacoma728's Avatar
A quality body lift will include bumper brackets. If you worry about the appearence of a bodylift over it's functional use, you don't need to worry about a body lift. Go three inches if you go or don't go at all.
__________________
Every 4x4 i own is sold, moved on to an economical car. SEE YA
tacoma728 is offline
Old 02-11-2008, 06:14 PM   #9 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
If you want to get easy lift, then just go with a 3" body lift. At 2" you are probibly going to have to extend everything you would with a 3".
A good kit will include most everything you need. But some things might need a little modification. ( simple things) IIRC the 4runners stock rear bumpers mount to the body, so no worries about lift brackets there.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 02-11-2008, 06:31 PM   #10 (permalink)
I'll prob take it to my local shop and have them take care of it.
Thanks for all your help!
Old 02-11-2008, 06:34 PM   #11 (permalink)
Jdizzydub's Avatar
I'm running 4crawler's 2in BL and it took around 4 hours to install. I wanted more tire clearance. The kit came with bumper brackets to raise the front, rear is attached. It also came with radiator brackets so it'll be in the right position and a steering extension. Great quality and product from Roger. Yeah the frame is a bit exposed, but nothing pond liner from home depot cannot fix, besides it makes it easier to change the oil filter and work underneath your rig.
__________________
97' 4RUNNER SR5 4x4
Lift:OME 881's OME Fronts w/ TOYTEC top out spacer, OME LC Rears
2in. 4crawler BL, SS Diff drop, Custom welded drop bar
Performance:Yellow Top,Custom Dual Vortex Exhaust, Magnaflow Hi-flo CAT, K&N FIPK, Diff Breather Mod
Wheels & Tires:315 16x9's on MOTO METALS
Lights:Silver Reverse Glow Gauges, Hella 500's
Armor:Trailgear Sliders, Taco ARB
"Sounds stupid. . .sign me up!"
Jdizzydub is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Quick "what's it worth" Question... toyotasaurus Pre 84 Trucks 10 11-08-2007 03:21 AM
worth keeping the "old" deluxe cluster? 2km5 86-95 Trucks & 4Runners 4 09-11-2007 07:08 PM
Another "How much is it worth?" Question GM TURBO 86-95 Trucks & 4Runners 8 06-19-2007 03:54 PM
Is it worth it? 2" or 4" susp JonnyMike 86-95 Trucks & 4Runners 3 01-19-2006 07:07 PM
Sylvania 19" CRT, how much is it worth? Corey Computer Talk 1 07-18-2005 07:35 AM
2009 InternetBrands, Inc.
