1991 4runner hub not locking
Axle spins for the 4wd but it does not lock to the hubs??? it worked great before it sat for a couple months??? Well when I put it into 4hi nothing happens no light or anything, don't even hear noise, but wen I put it in 4lo, the same thing happens except it goes slower cus its in 4lo, but my neighbor is a mechanic and he gave it a quick check before he left for vacation and he said the axle for the 4wd is not locking to the hubs, so he thinks it might be on of the hubs, but i need to fix it because there is a lot of snow here where i live about 2 feet, and he is not coming back till like saturday so i need help?? And there automatic hubs and its a 5speed 4runner v6.
If its a stock 4Runner setup, it will be ADD.
And going on that assumption, its not the hubs that are causing the problem. With ADD, the hubs are always locked, via lock plates. There is no way from the front axles to NOT be spinning, unless you shatter/break something wheeling. Just sitting for a while won't cause said breakage.
Likely, your ADD actuator is not working, or is corroded.
For ADD you have drive flanges not locking hubs. Basically drive flanges are like hubs that are permanently locked. ADD problems are usually related to mis-plumbed vacuum lines:
- http://www.off-road.com/toyota/tech/add
well i check the vacumm lines under the hood and they look correct too me but i couldnt locate the ones by the wheel..
06-01-2021 01:51 PM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
