Off Road MODS wish list priority - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Old 10-02-2008, 07:06 PM   #1 (permalink)
USMC_4runner's Avatar
Send a message via AIM to USMC_4runner
I bought my 4runner (silver '05 SR5 4wd) back in july and have since taken it off road a few times. I'd like to turn this into a somewhat serious trail rig during the next year or two. Haven't really done anything yet but i wanted some input. I'll be going active duty (USMC) in 2 months so i'm not planning on commuting much in the next 10-20 years (hopefully) so a hit in a few mpg isn't going to kill me, however i would like some input on what these mods will do to handling/performance/economy. Right now, i'd like to put a shrockworks bumper (or maybe ARB depending on the wait), winch, OME kit, Sliders, beefed up skid plates, and maybe a rear locker (ARB) if i get stationed somewhere where i'll need it. What would be the best MODS to do first (i'm thinking ordering the bumper, then getting the suspension when the bumper arrives since you need a beefed up suspension for the bumper) and then adding on from there.
USMC_4runner is offline
Sponsored Links
To remove this ad, register today!
Old 10-02-2008, 07:26 PM   #2 (permalink)
scuba's Avatar
I remember reading the statement before the order should be.
1. Lockers
2. Armor
3. Lift
4. Tires
Someone correct me if im wrong
__________________
GO BOLTS!!
91:THUMPIN TRUCKIN LIFTED AND LOCKED WRECKED
86 2x4In the crusher since 09/08
I have bad luck
Spring Break Much?
http://www.yotatech.com/f15/spring-b...und-up-158664/
Pacific Crawlers
UltimateYota
scuba is offline
Old 10-02-2008, 07:34 PM   #3 (permalink)
flatland4runner's Avatar
Yeah do the locker(s) first then build from there. By then the lockers will let you get far enough to realize the need for armour.
__________________
'91 4Runner SR5- 3.0 -5spd-Aisin Manual Hubs-ISR mod
flatland4runner is offline
Old 10-02-2008, 07:51 PM   #4 (permalink)
Chapman88SR5's Avatar
Send a message via AIM to Chapman88SR5
Tires are by far the best first upgrade, unless you can afford lockers.
__________________
1988 4Runner 3.Slow
-33x12.5 Mickey Thompson Baja MTZ Radials
-4Crawler 1.5" BJ Spacers
-OME 2" Leaf Springs
-Flowmaster 44
-Engine replaced at 200k
-Green Rattle can paint
The early bird gets the worm but the second mouse gets the cheese. Hmmm...
See more in the Check out my Truck section
God works through Christians; I am a Christian.
-George W. Bush
Chapman88SR5 is offline
Old 10-03-2008, 12:44 PM   #5 (permalink)
To some extent, its a matter of opinion about the best order for mods. I think its important to know where you want to go with it so you don't waste money changing the same thing twice.
I agree that a good set of tires should be the first priority - the original equipment tires are street tires, provide poor traction and won't take much abuse.
I would hold off on lockers until the end. The ATRAC on these truck works fairly well and is definitely better than your typical 4x4 with open differentials. Besides, considering the poor ground clearance these trucks have in stock form, having a locker without a lift and sliders will just get you into trouble.
My second priority would be either armor or a lift. You can make arguments for both. Sliders and skids are a definite must if you want to wheel hard and if you don't have a lift, you will definitely make use of them on moderate trails because of the poor ground clearance. If you lift before sliders and skids, you should be able to run moderate trails without too much worry. If you invest in some adjustable coilovers, you could lift early on and adjust them later to compensate for added weight from armor, bumpers and winch.
By the way - I have OME lift, Shrockworks sliders and 265 70 r17 BFG all-terrains on my 4-Runner. I did the lift and tires soon after I bought it and added the sliders a few months later. I am very satisfied with this set-up.
__________________
79 longbed 4x4
03 4-Runner 4x4 (DD)
scottd is offline
Old 10-03-2008, 01:00 PM   #6 (permalink)
crolison's Avatar
Quote:
I used my armor a while before i had a locker.
I saw:
-Sliders
-locker
-lift
-tires
my next step is rear bumper, then crawlbox
__________________
97 4runner, 2.7 5speed 4wd, 4.88, 255/85/16 Maxxis Bighorns
rear diff breather, 4 hella 500's driving, sliders, wilderness rack
custom bumpers
arb locked f&r
toytec adjustables, ome 891's, bilstein 5125
manual hubs
warn xd9000i
broken front and rear swaybars
My Profile
crolison is offline
Old 10-03-2008, 01:49 PM   #7 (permalink)
Matt16's Avatar
Considering the ground clearance on these trucks isn't great, I'd do armour first. Oil sump, tranny, T-case, and gas tank, then rear bumper, sliders lastly front bumper.
Then choose a tire size and lift to match, no more. Then get lockers and gears all at once.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is online now
Old 10-03-2008, 05:39 PM   #8 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
Tires
Lift
Armour
Locker(s)
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l
TOYOTA TOUR 2008
トヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 10-20-2008, 02:39 PM   #9 (permalink)
SAINT_B's Avatar
My stock 06 4RUNNER V6 has nearly complete skids minus rear diff. I just installed OME 885 front and 895 rear with stock x-reas shocks. I love the ride. Very smooth. Next I will be getting tires (285x70 17). Just throwing the info out there. Oh my runner sits only 3/4 of an inch high in the rear. Perfect!
SAINT_B is offline
Old 10-20-2008, 03:24 PM   #10 (permalink)
Quote:
Which skids do you have? Does the OME shock/coil work with x-reas, or did you have to remouve the x-reas? How the OME set up compare to the stock x-reas in handling and ride?
As for the OP question (not to totally hijack the thread) I am going with armour before tires/lift mainly because it is more affordable.
Will_4R is offline
Old 10-20-2008, 03:30 PM   #11 (permalink)
algranger's Avatar
it depends on what you want out of your truck. if you want performance, go like this
locker
lift
tires
trail armour
if you want the feel and look of a modded lifted truck go
lift
tires
armour
locker
or switch lift/tires with armour.
algranger is online now
Old 10-20-2008, 08:09 PM   #12 (permalink)
SAINT_B's Avatar
kept the x-reas shocks. Ride is smoother due to better quality more progressive rate OME springs. X-reas does work with the lift I will loose a little articulation at full extension due to stock shorter length shock. I am very happy with this set up so far. Virtually no body roll and smooth valving in the x-reas Yamaha shocks. If you get your rig up off the ground you are far less likely to make contact unless you are rock crawling. I installed all 4 springs myself. It was easy and the lift (3RUN-FRC-885) is $359.99 from TOYTEC.
SAINT_B is offline
Old 10-20-2008, 09:09 PM   #13 (permalink)
So if I understand you, I can install just the OME spring with the stock shocks? You don't need the OME shocks with the springs? I wonder if the the x-reas shocks can work with the x-reas part or our suspension system.
It sounds like your set up is pretty good either way. You got the lift for a good price, and the stiffer springs for added armour. I am guessing this is better than just a spacer lift.
Will_4R is offline
Old 10-21-2008, 02:41 PM   #14 (permalink)
SAINT_B's Avatar
Yes with x-reas you can install just the front and rear springs. If you would like I can send some pics of my truck: me e-mail address is saintbeau@gmail.com
SAINT_B is offline
Old 10-23-2008, 05:59 PM   #15 (permalink)
SAINT_B's Avatar
http://c1.ac-images.myspacecdn.com/i...2691aa1c90.jpg
SAINT_B is offline
Old 10-23-2008, 06:01 PM   #16 (permalink)
SAINT_B's Avatar
[IMG]//c1.ac-images.myspacecdn.com/i...2691aa1c90.jpg[/IMG]
SAINT_B is offline
Old 10-23-2008, 06:02 PM   #17 (permalink)
SAINT_B's Avatar
SAINT_B is offline
Old 10-23-2008, 06:02 PM   #18 (permalink)
SAINT_B's Avatar
SAINT_B is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
And the List of Mods continues Ritzy4Runner 95.5-2004 Tacomas & 96-2002 4Runners 6 12-20-2007 08:01 AM
List any mods for 86-95 here Joyota 86-95 Trucks & 4Runners 15 08-20-2006 01:43 PM
List of Mods/Upgrades needed for '05 Taco Dcab PirateFins 95.5-2004 Tacomas & 96-2002 4Runners 11 07-22-2004 08:26 AM
4th Gen Mods/aftermkt wish list JGage 03+ 4Runner/GX470, & 05+ Tacomas 8 01-12-2004 01:59 PM
List your failed mods. SLC Punk Off Topic Talk 20 09-23-2003 08:56 AM
