| Home | Photo Gallery | Register | All Albums | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Search this Thread |
#1 (permalink) |
I've got an 04 4Runner SR5 4WD with 17 inch wheels. Are my wheels hub, or lug, centric?
| Sponsored Links |
#2 (permalink) |
Likely lug centric, but the easy way to tell is look closely where the wheel meets the hub. If you see a gap between the wheel center hole and the hub, then the hub is not centering the wheel.
On my '85 4Runner, there is at least a 1/8" gap all the way around between the hub and the wheel. And when you put the wheel on the hub, you need to lift it up and align the lug holes with the studs. So the lug studs and nuts both center the wheel and hold it to the hub. On my VW, you can put the wheel onto the hub and it slips over a centering ring and will sit there without any of the lug bolts installed. In fact you put the wheel on like that and then you thread each lug bolt into place, so all the lug bolts do is hold the wheel to the hub, it is already centered.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#3 (permalink) |
Thanks
I appreciate the info. Thanks for replying.
#4 (permalink) | ||
All factory toyota alloys are Lug-centric
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts! Quote:
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hub Centric OR Lug Centric | cruzinrob | 03+ 4Runner/GX470, & 05+ Tacomas | 6 | 02-02-2008 09:11 PM |
| Sequoia wheels: lug or hub centric? | Net4N6 | General Vehicle Related Topics (Non Year Related) | 33 | 11-09-2006 03:40 PM |
| hub centric or Lug centric | SteveO | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 07-06-2003 05:35 PM |
| Lug-centric or hub-centric (again) | Erc | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 04-29-2003 03:25 PM |
| Hub centric or Lug centric | Sgary | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 02-08-2003 10:22 PM |
