DAC Switch Questions
Old 07-26-2011, 04:24 PM
colorado-yota's Avatar
In my 2003 Four-Runner, I don't understand under what conditions I should engage the DAC switch. I get that it is for downhill assist, but under what circumstances should I use it? Towing a travel trailer, I can't tell that there is any effect so I go ahead and downshift the transmission to lower gears. I engaged in 4-low on a steep downhill grade and got an alarming loud clunking noise from the brakes and immediately shut it off. So when should I use it?
If you don't mind, please give me some technical information as to what happens when it is engaged. Apparently it works with the anti-lock braking system.
Thanks.
okamikai
04-30-2018 10:19 PM
ghostmoney
01-28-2018 11:42 AM
TJWilly
07-31-2015 02:05 PM
stock87yota
07-31-2015 10:08 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: DAC Switch Questions
