| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
CEL & VSC\TRAC Lights after Seafoam Treatment on 03'
__________________
Supercharged 99' Tacoma TRD 03' 4Runner Sport Edition V8 |
#2 (permalink) |
Unless the CEL rears its ugly head again, I wouldn't take it to the dealership. You'll just end up waisting your time and not finding out anything new (can you tell how I feel about the dealership by the statement
#3 (permalink) |
Thanks.. I don't care for them either. I've done all the maintenance since it was new. I don't trust a single dealership to work on my stuff.
__________________
#5 (permalink) |
I lived in Woodbridge most of my life. I just recently moved to King George near the Stafford Co line to get away from what it's turned into over the years. I still work in the city and commute via I95... Roughly 55 miles 1 way. I'm a sick man..
__________________
#6 (permalink) |
it probly had misfire codes from running the seafoam thru the intake system.most any time we do a DECARB service on one which uses the same procedure we have to reset the light.it only takes a very small mis fire to trigger cel.likely all it was,when system checked again all was ok
__________________
91 4runner,5spd,bone stock,rblt 3.0 @ 303,000 miles.OME 900 rear springs,front & rear shocks.97 runner wifeys |
#7 (permalink) | |
Quote:
Makes sense and misfire sounds right. It did seem to stumble longer then usually on start up. Then it ran extremely quiet but rough like it was missing on a cylinder. How long does it take for a CEL to clear on it's own if the problem is corrected? For example: Let's say I had to replace the o2 in my scenario.... After installing the new o2would I have to clear the code manually, or would the computer detect the new sensor?
__________________
#8 (permalink) | |
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| VSC TRAC, TRAC OFF, CHECK ENGINE lights | nathan gailey | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 04-09-2008 08:08 PM |
| Disabling VSC & TRAC - 2001-2002 4Runner with VSC & TRAC Systems | Writeups@YotaTech | Electrical | 0 | 01-11-2007 09:29 AM |
| VSC off, VSC Trac and CEL came on after putting in K & N Air Intake | HenrySacto | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 12-30-2005 02:16 PM |
| 04 4-runner Transmisssion VSC Trac VSC off lights | freemanc | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 03-10-2005 10:57 AM |
| CEL, VSC and TRAC on 4th gen | darkstar | Off Topic Talk | 3 | 10-13-2003 10:29 AM |
