Anyone with a newer lifted Tacoma (2005+)
I've had my 06 TRD Tacoma 4x4 for a couple years now, put 35,000 on the tires, they're sort of getting to the point of being done, so it might be time to replace them before I move back to Tahoe next month.
I was debating going bigger for better clearance and a more aggressive tread. Has anyone done a 3" to 4" lift on your Tacoma?
Any issues?
How's the MPG?
How big a tire did you go to?
Anything you'd do different?
Can I run a bigger tire (32", 33") on the stock rims?
Any issues?
How's the MPG?
I have got an '05 taco with a daystar spacer lift (not the way to go IMO) I run 285's on Ultra Rims with 4" BS and rub the body mount periodically at full lock and compression. I have got a set of studded 285's mounted on the stock TRD Rim that I run during the winter. The BS spacing is not enough with the stock rims (4.5" I think) I get get a lot of rubbing on the stock UCA when running those rims. If you lift I would consider different rims though a lot of folks seem to be fine with them, they may have upgraded their UCA's and using a Coil lift vs. spacer probably nets better clearance....
MPG is not too bad, about 17 MPG combined, it is a truck not a PRius
I'm waiting for my Skyjacker 3" lift to arrive. Mine will be all new springs, shocks, and struts. Unfortunately, Skyjacker is out of the struts right now and I have to wait on them to make them.
The way I figure it, I need new tires. But I eventually want to lift it and go with bigger tires, and don't want to buy new ones now, then buy them again later to get a size that matches the lift. So I went ahead and ordered the lift.
Might as well do it all at once.
We just finished an 07 DC Tacoma.
3" suspension lift
3" body lift
255/60/18 BFG KM2s
American Racing Teflon coated rims
All the info here and more pics:
http://www.wabfab.org/projects/07Taco/07Taco.htm
3" suspension lift
3" body lift
255/60/18 BFG KM2s
'05 with Daystar 'leveling kit' upfront, AAL rear, hopefully to be replaced with OME's. 285's on 4" BS rims, rub on the front body mount at full lock and compression
edit: sorry did not notice i had already posted in this thread
Wabbit~
That truck looks pretty sweet minus that nasty frame showing
It needs painted really bad or something....maybe sell him some sliders
Im not trying to bash on someones truck but that needs some lovin.
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
