4th Gen 4Runner-FJ 40 transfer case swap - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 03+ 4Runner/GX470, & 05+ Tacomas
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-03-2006, 08:12 PM   #1 (permalink)
I am a new member and must say this forum has some great info. I have an 03 4Runner- the biggest drawback to me is that Toyota does not offer a locking rear diff in this model and you turn a button to activate the 4WD . Has anyone tried swapping a center diff from a 2007 FJ into a 4Runner, and then cutting a hole in the floor for the shifter? I know it sounds like a lot of work but I'd sure be interested in knowing whether it can be done.
Thanks!
03-4RunGalactic is offline
Old 10-03-2006, 10:30 PM   #2 (permalink)
Good Times's Avatar
Send a message via AIM to Good Times
Nope not here. How about just getting the Atlas 4 speed transfer case instead? It replaces the stock transfer case and for the same size you get ultra low gears for rock crawling
http://www.4wheeloffroad.com/2006ult...kup/axles.html
Wouldn't mind doing this myself actually but obviously the costs takes me out right away.
Good Times is offline
Old 10-03-2006, 11:42 PM   #3 (permalink)
AxleIke's Avatar
Okay, your title says 40, but the post says 07 FJ. I'm assuming you're talking about an 07 FJ.
For the record, you DO NOT want the 40 case. It is a 1 piece unit, and it works okay in 40s behind the stock straight 6's, but they will break open with too much power being pushed through them.
I will second the Atlas 4 speed. You get hi, low, low low, and really low low. Another great benifit is that it is cable shifted, so you can mount that bad boy, if you wish, in the cab, with only a wire coming through the floor. Plus, its just a sexy beast.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction
-Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail.
-Internet Nice Guy
AxleIke is offline
Old 10-04-2006, 12:54 PM   #4 (permalink)
Thank you Good Times and AxleIke. I looked up the Atlas 4 speed- nice set up but that's a whammy of a price tag. I guess I'll hold off until I win the lottery! Anyone had any problems with their 4th Gen transfer cases? I bought some water proofing tape with foil-type material on the back. For now, I'll just wrap the harness going to the transfer case with that to try and avoid any shorts during water crossing, etc.
Old 10-04-2006, 01:00 PM   #5 (permalink)
Good Times's Avatar
no problem and btw, welcome aboard!
I personally wouldn't mind testing out the atlas if it fell in my lap (hint hint for anyone out there! hehe).
As for water crossings, I've seen many 4th gens make it across with no problems so I wouldn't worry too much about it.
Old 10-04-2006, 03:58 PM   #6 (permalink)
Mikestang's Avatar
What's wrong with turning a knob to engage 4wd?
__________________
'04 SR5 4Runner v8 4x4
Magnaflow cat-back, rear diff breather mod, Surco rack, 265/75/16 Goodyear SA, Midland 75-822, Wilson 5000, Shrockworks bumper, PIAA 510s/580s, Scion T1806 w/iPod, Demello sliders, DR COs UCAs monotubes, Deaver coils, Pro Comp alloys, Slee SS lines, Garmin 276c, Optima yellow top, BudBuilt skids, 2wd sway, WabFab links, KurtFab LCAs
www.mikestang.com
Mikestang is offline
Old 10-04-2006, 04:25 PM   #7 (permalink)
Good Times's Avatar
The old saying goes "Keep it simple stupid". When things go wrong, trying to fix a mechanical thing is easier than something electronic.
Old 10-05-2006, 11:44 AM   #8 (permalink)
4Mogger's Avatar
Quote:
Thanks!
I don't see the point. There are no issues that I know of with the push button V6 cases. I swapped one INTO my '94 4Runner.
I like it because all you have to do is hot wire it for 2WD low range.
As for the rear diff. Get a selectable locker and go wheel.
4Mogger is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
pic request? Fj transfer case shift knob. soarerjzz30 FJ Cruiser 0 04-25-2007 08:30 PM
Fj Cruiser Transfer Case Question milowilli FJ Cruiser 8 01-07-2007 04:28 PM
4th Gen Transfer Case Skid Plate Teotwaki Offroad Tech 3 06-18-2006 09:17 AM
64 FJ 40 axle swap Corbit The Fab Shop 1 08-27-2005 04:12 PM
Ford 302 Engine i 4runner swap transmission+transfer case problems travisdahl 95.5-2004 Tacomas & 96-2002 4Runners 7 02-11-2005 01:43 PM
2009 InternetBrands, Inc.
