05 4runner timing belt problem.
Old 06-01-2013, 03:02 PM
chrisw83's Avatar
I have replaced my timing belt and all the marks line up except the 2 marks on the timing belt that are for the cam gears. The crank, left and right cam gears are all lined up but I cant seem to get the marks on the belt to line up with the cam gears. Should I worry about these marks? They are on off by 1 tooth to the right.
Old 06-01-2013, 04:38 PM
rworegon's Avatar
You are using as Toyota does:
Right = passenger side
Left = driver side
Old 06-01-2013, 04:54 PM
chrisw83's Avatar
Facing the truck right to the driver side
Old 06-01-2013, 05:42 PM
rworegon's Avatar
No, driver side is left.
Toyota uses right and left on the engine as if you are sitting in the driver seat looking forward.
Thus:
Radiator
Left...................Right
Driver Side..........Passenger side
Old 06-03-2013, 07:54 AM
chrisw83's Avatar
Thank you. I went back to read the manual and noticed that in the pictures. Flipped the belt around and it went together smoothly!!!
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
layifioren
10
07-06-2015 02:26 PM
crazypaint
06-23-2015 03:27 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 05 4runner timing belt problem.
