'03 vs. '05 4Runner V8 Towing?
Old 09-20-2007, 09:31 PM
dragr1's Avatar
Other than more power, why is the '05 V8 4Runner rated at 7000 pounds to the 5000 pounds of the '03 4Runner?
Old 09-21-2007, 12:22 AM
TechWrench's Avatar
The original '03 V8's came with the lower rating hitch (5000 lbs) that the V6 had, but about mid-year, there was a production change to the heavier (7000 lbs) weight distributing hitch for the V8's. If I remember correctly, once the hitch was upgraded in mid-'03, all the subsequent V8's came with the higher rated hitch if they had the factory tow package installed.
Old 09-21-2007, 03:39 AM
dragr1's Avatar
OK, then I guess the newer hitch could just be installed on the early models then.
Old 09-22-2007, 12:04 AM
TechWrench's Avatar
As I recall, some people were getting a free upgrade to the heavier hitch for a while after the production change was made. But it would probably be difficult to get a free one now. I think there is a hidden hitch available that will do the trick for you.
RyanJ989
11
04-07-2021 09:41 AM
Bourbonblues
12-15-2017 05:43 PM
mojo4x420
09-16-2015 08:07 AM
seab1209
09-03-2015 05:41 PM
vanion2
07-29-2015 06:17 PM
Quick Reply: '03 vs. '05 4Runner V8 Towing?
