yay, new light installed today
Old Sep 10, 2008 | 05:32 PM
iamsuperbleeder's Avatar
there was fair enough weather today after work, I so installed my new lights on my bumper...
first off, the old, cheapo, little dinky ones I had on there...
got em for like $10 at my old job... can't really complain, they served their purpose for over a year...
but recently I noticed one had a broken lense, so I got some new ones with money from my new job
MUCHO EL BRIGHTERO!
kinda blurry, took em from my phone...
huge difference though, both in size, and how much light they produce. had to make the mounting holes a lil bigger, and they just barely fit in front of the grill, they stick out some, but all is well... only thing I have to do now is upgrade the main power wire leading from the battery to the fuse, then from the fuse to the relay... the wire's not quite thick anough to carry the juice for both 100watt lights... I changed the relay to a better one, but didn't have the time to go and get wire, a fuse holder, and a fuse to install... maybe I'll hit that this weekend and pick the stuff up when I go to get my u-joints... not gunna be using them for now, so no worries...
for 2 100watt bulbs, what do yall think, a 40amp fuse will do?
Old Sep 10, 2008 | 06:02 PM
91Toyota's Avatar
Knock off KC's?
Old Sep 10, 2008 | 06:10 PM
Originally Posted by 91Toyota
Knock off KC's?
haha, yeah, basically. we used 8 of em on my buddies Dakota woods truck; 4 facing forward on the roll bar, 2 facing out to the side, and 2 facing back. they've lasted for years now, no rust, and are bright as all hell, so I thought I'd give em a shot; till I get my procomp bar for the front, then I'm installing hella's
I need to get some covers for them though...
Old Sep 10, 2008 | 06:24 PM
MMA_Alex's Avatar
40 amp?
you need to size the fuse for the wire and the wire for the load.
200 watts @ 12v = 16.5A
you're looking @ a 20 amp fuse and at least 16 awg wire, you'd be better off with 14 awg, and will actually get brighter lights because there will be less voltage drop
Old Sep 10, 2008 | 06:32 PM
hmmwv15's Avatar
I got a pair with wiring made by hella, they are optilux 9000 I believe, 100 w bulbs for like $40 at advance. Best set of lights I've ever had. And they look like KC's so I get the cool factor I don't like the chrome though.
Old Sep 10, 2008 | 06:44 PM
Originally Posted by MMA_Alex
40 amp?
oh, nm, for some reason I was thinking the fuse to my old cheapo's was a 30a, it was a 15a
what's funny is what it did to that fuse...
AND THAT FUSE STILL WORKED!
lol
but yeah, I don't even have a fues in the block right now, I took it out to keep my from even TRYING to turn them on... I turned them on with a 40a in the block just to test the wiring and make sure they worked, but after about 30 seconds of being on, I noticed the main power wire was getting a bit warm...
yeah, if I would have been thinking (or rather had the time) I would have blacked em out before installing them, but I guess they blend in with the rest of the chrome on the front of the truck...
Old Sep 10, 2008 | 09:32 PM
space-junk's Avatar
hmm... looks good... another idea, my buddy and i got together and i came up with the idea of wiring them through my high-beams... works like a charm, and whats even better is that when i turn my highs on, not onlydo i get the projecting light, i get the flood to the sides of the truck from the stock headlamps too... if anyone wants to see how i did it, then i can post up some pics of it...
Old Sep 10, 2008 | 09:37 PM
Elton's Avatar
please tell me your using a relay
Old Sep 11, 2008 | 03:14 AM
lol, yes, I'm using a relay...
I've done that with some in the past, but I like total control over my lights... I just have a togle on the dash to turn em on or off, regardless if the headlights are on or of. the ignition has to be on though to "arm" the swith that kicks in the relay
Old Sep 11, 2008 | 03:18 AM
MMA_Alex's Avatar
how'd you manage that? I tried, but decided it was too much work because of the way the lights are switched. I do however have mine setup so that the headlights need to be on either high or low to have the driving lights on to save my battery.
ashersullivan88yota
Jan 18, 2022 05:37 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
Odin
Jul 15, 2015 09:28 PM
