Writeup: removal of third and locker install - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 12-10-2008, 10:13 PM   #1 (permalink)
Personal Sales Rating: (0)
Matt16's Avatar
The differential found in the back of many Japanese trucks (and certain domestic axles such as the Ford 9") is mounted in a removable housing that allows for it to be set up at a work bench. This is the case for the rear end of all Toyota trucks and 4Runners. One benefit of this is the ability to swap gear ratios around between trucks. While this isn't difficult to do, it helps to know the steps involved, if for no other reason than to plan how much time to set aside. First time I did this it took me about 4 hours, stopping for break, and cleaning the underside of the truck at the same time. Your mileage my vary.
Note: Sorry, I don't know torque values. They are available in the FSM link, or by searching.
Tools:
  • 10, 12, 14mm wrenches
  • 10, 12, 14mm sockets and socket wrench
  • 24mm socket for diff drain and fill plugs
  • >3" socket extension
  • razor blade or gasket scraper, steel wool is also helpful
  • empty beer bottle or jar, as well as 3 feet clear 1/4" tubing for bleeding brakes
  • a wheeled creeper is helpful
  • 2 jackstands
  • some sort of jack
  • oil container to drain oil into.
Fluids
  • 3 quarts (actually 2.3 quarts) 80W90 gear oil (or thicker- I use 85W140 to quiet my locker down)
  • minimum a quart of DOT 3 brake fluid
  • oil resistant RTV sealant (I've used black, ultra grey and ultra copper, none leaked)
  • blue (med strength) thread locker.
PART I- Third member removal procedure:
  1. Take the truck for a spirited drive to warm up the gear oil.
  2. Disconnect the 4 14mm bolts securing the rear driveshaft to the third member. Sometimes you need to get a chisel in there to separate the driveshaft from the pinion flange on the third member.
  3. loosen the lug nuts
  4. jack up the truck and support it with jack stands
  5. open the differential fill plug bolt, THEN undo the drain plug. The rational behind this is that if you drain the oil, then find out there is no way to refill it, you're looking at hiring a flat bed to take your truck to a mechanic to get the fill plug open
  6. Remove the wheels, then the drums. The drums are simply sandwhiched between the wheel and the hub.
  7. With your fingers or a set of pliers, undo the parking brake cable.
  8. Undo the 4 bolts securing the hub to the axle housing.
  9. Undo the brake line where it enters the back of the backing plate (not sure what exactly its called, please correct me if you do).
  10. Get a plastic bag and put it over the open end of the brake line. Secure with an elastic. This prevents the brake fluid from gravity bleeding out of the line. THis is quite important as is all the brake fluid drains out (over several hours) and the master cylinder drains dry, then you've got to bleed the MC (lots more work).
  11. the axles should pull out freely from the axle housing now. Remove them completely (best not let rest them on the axle seal, as the axle may start leaking) and set them aside. Here is the seal you are trying to avoid damaging.
  12. REmove the ABS pigtail from the diff as so, it comes out the top of the diff and extends to the body.:
    Quote:
    Originally Posted by space-junk View Post
    ... all that is required to remove the pigtail from the housing is a 12mm socket to undo the 1 support bracket from the 3rd member outer ring, and 1 bolt holding the sensor down... then get a big long flat head screw driver and work your way under the sensor and slowly keep prying up on it till it pops out...
    took me about 3 mins to pry mine out...
    also, its prolly best to do that after you have the dif out on the jack... makes it easier to turn the wrench...
  13. Unbolt the third member from the axle housing. I think there are ten 12mm nuts to remove. Its 60lbs or so, but it won't just drop on you as it will hang up on the studs. You do have to wrestle is out a bit. Putting a floor jack under the pinion flange will break the diff-axle housing seal (that RTV holds really well).
  14. I find it easiest to position myself under the axle laying on a creeper and wrestle it out onto my chest. If you have a rear swaybar, the diff may catch on this. To remedy this, you can unbolt the swaybar end links from the frame.
The install is basically the same as the removal, with a few extra steps.
You must scrape the gasket material off the mating surfaces of the axle housing and third member. They must also be free of oil. I use break cleaner on the surfaces once most of the oil is gone. Once this is done, apply a 1/4" bead of RTV gasket material on the third member making sure to go completely around each bolt hole. Then place the third member into position and bolt into place. Only tighten the nuts a little more than finger tight just yet. Let the RTV sealant dry (vulcanize actually) for an hour or two then tighten the bolts to (the appropriate torque).
Apply liberal amounts of blue (medium strength) thread locker on the driveshaft-third member bolts and the 4 bolts which bolt each end of the axle housing to the hub.
Reattach the rear brake lines after removing the plastic bags, and tighten the bolts to 7ft-lbs (not much at all, even with a 6 inch long box wrench. Finally bleed the brakes. There are plenty of writeups on this, so I'll let you search. Here's one: http://www.4x4wire.com/toyota/mainte...leedingbrakes/
If any grease/oil got on the rear brake shoes, spray it with brake cleaner.
REMEMBER to refill the axle with oil. The thinnest oil I'd use is a 80W90.
All done:
PART II- Installing the a lunchbox locker
Note: this is the procedure fir a 4 cylinder rear diff, although many of the more difficult steps are the same.
Here's another install link, where I got a lot of my knowledge: http://gearinstalls.com/bill.htm
  1. spray down the third member with brake cleaner to make the job less messy
  2. place the third member in some home-made jig to hold it still.
  3. Mark the adjuster nuts relative to the bearing caps, use different markings for each side (ie: I used a double punch mark on one side, and a single one on the other)
  4. Its crucial to make sure the bearing races and marked bearing caps go back on the side of the carrier they came off of. I used to marked plastic bags- one for each side.
  5. Mark the ring gear relative to the carrier.
  6. Remove the ring gear from the carrier with an impact wrench or use whatever you have (do not apply a torch).
  7. With a drill bit about the size of the roll pin, drill out the dented toll pin hole
  8. tap out the roll pin using a nail or sacrifical punch or drill bit.
  9. the cross pin, spacers and spider gears should fall out. Keep track of which shim washer came from which side as these are re-installed with the locker
  10. Assemble the locker (really simple to do, no explanation necessary), take the measurements its asks for with a $3 feeler gauge from an autoparts store. Note bags used to prevent grit from getting in the bearings.
  11. Put the roll pin back in and dimple the opening with a punch to prevent the pin from backing out
  12. tap the ring gear back on with a piece of wood. Remember to lined it up so it is the same orientation as when you removed it. If it is too tight, warm it up until it is too hot to hold for long, but not long enough that it burns you (or else you may ruin the metal temper). Bolts ring gear back on to carrier. Use red thread locker and torque to spec.
  13. Apply aluminum-based anti-seize compound to the treads of the bearing cap, third member and the outside of the bearing races
  14. Place races in on the bearings (on their respective sides- don't mix them up!!!) and lower the carrier into the third member.
  15. Place adjuster wheels in position on their respective sides (or else markings will be useless)
  16. Place the bearing caps in positions (again, on their respective sides) and hand tighten the bolts.
    IMPORTANT STEPS that I misread the first time:
  17. Make sure the adjuster wheel thread aren't cross-threaded, then tighten the ring gear-side adjuster (teeth pointing AWAY from this adjuster wheel) until the backlash is zero, then back the adjuster out until the punch marks lines up. This should be less than one full turn. Tap on the bearing cap as you're doing this to make sure the treads settle properly.
    ^ maybe not
  18. Tighten the pinion-side adjuster wheel (the side being faced by the ring gear teeth) until it reaches it's mark and has some resistance to turning any tighter. Tap on the bearing caps while doing this, after the adjusters have reached their mark, hold the pinion flange (where the driveshaft bolts to) and try to turn the ring gear back and forth. It should make a tiny tapping noise indicating that there is the tiniest bit of play between the gear. The amount of play should be small enough that you should be barely able to notice it with the naked eye.
    I copied Zuk's adjuster tool. Its just a flat piece of metal with two bolts going through it that line up with the holes in the adjuster wheel.
  19. Once the BL is reset, torque both bearing caps down and bolt on the little adjuster wheel lock.
  20. Re install the third member as described above.
Locker test
After the locked third is re-installed in the axle and the axle filled with gear oil. Jack both rear wheels off the ground and put the tranny in neutral. Spin the tires by hand one way then jerk it the other way, it should unlock from the other tire, and make a clicking sound. If so, the locker is good to go for a drive.
I did a review of the Aussie Locker, it has lots of info on driving a lunchbox (spider replacement) locker in general though. Here's the thread: http://www.yotatech.com/f105/aussie-...review-143163/
__________________
My '86-95 4Runner/ truck writeups SEE HERE
1987 Toyota LandCruiser HJ60 6 cyl. 2H diesel, 5spd, totally stock... for now
1990 Toyota 4Runner 22RE 5spd SOLD
1987 Toyota P/U, 2wd auto, 1 tonne SOLD
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Matt16 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 12-10-2008, 10:21 PM   #2 (permalink)
When in doubt, drink heavily!
Personal Sales Rating: (9)
Staff
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Change #1 to two 14mm wrenches.....please don't tell people to use Vice grips on bolts, ever.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by BigBluePile View Post
Hmmm, dunno. Ask the oem Nazi DC.
Quote:
Originally Posted by waskillywabbit View Post
Dare I say this...but I agree with MudHippy.
DeathCougar is offline
Old 12-10-2008, 10:23 PM   #3 (permalink)
toyospearo's Avatar
Nice write up.
I have an Aussie coming on Mon. I need to pull the third to re gear and install the locker. This write up came at the right time!
__________________
94 Ext. cab 22re and a 1982 22r
Aussied, 4.88's, SAS,ed, FLATBED, OME leafs w/ 5.5" shackles, sliders,
LC Header, Marlin clutch,
32's- Swamper TSL's- RC rims, lifted, lighted, winched, LC high output alternator, etc etc..
My 82 build
http://www.yotatech.com/f197/toyospe...thread-211943/
My SAS thread
http://www.yotatech.com/f152/great-w...ck-sas-164531/
My Flatbed build thread
http://www.yotatech.com/f88/toyospea...-build-191787/
toyospearo is offline
Old 12-10-2008, 10:26 PM   #4 (permalink)
breknraj's Avatar
#4 also allows the diff to drain more efficiently, without the burp and possible mess.
__________________
Raj : 1960 Homo Sapien. 192cm, Blonde, Blue. Soon to lose spare tire.
Worf : 1990 SR5 Xtracab 4x4 5 speed, Inca Red Metallic. 3.4 converted, with Taco 5 spoke alloys, 275/65R16 BFG AT K/Os. Soon to add rear e-locker.
breknraj is offline
Old 12-10-2008, 11:29 PM   #5 (permalink)
Threadstarter [OP]
Matt16's Avatar
If anyone has more pictures that may be appropriate for this write up, please post them and I'll include them in the write up (if you don't mind).
__________________
Matt16 is offline
Old 12-11-2008, 02:04 PM   #6 (permalink)
Licensed Lunatic
Staff
iamsuperbleeder's Avatar
travishbleederdude
I like the fact that you noted to pull the axels ALL THE WAY OUT and not to rest them in the axel housing!
Also, once you get those axels pulled out, if your rear-wheel bearings look and act like this:
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
REPLACE THEM!
and those outter seals...
excellent write up man!
__________________
Read them. Follow them. Live by them.
just call me Travis
iamsuperbleeder is offline
Old 12-11-2008, 10:18 PM   #7 (permalink)
Threadstarter [OP]
Matt16's Avatar
Quote:
p man!
Its odd that they would both go so far. Were they ever greased?
__________________
Matt16 is offline
Old 12-11-2008, 10:29 PM   #8 (permalink)
SR5
SR5's Avatar
Quote:
couple somewhat related pics
__________________
1995 4Runner build thread [Off Road Meance]
1994 4runner build thread [Street King]
Jeep Recovery Vechile = Toyota
Toyota Recovery Vechile = A1 Abrams Tank
SR5 is offline
Old 12-12-2008, 06:01 AM   #9 (permalink)
5 Year Member
InternetRoadkill's Avatar
The plastic bag trick on the brake lines is messy. Use a couple of rubber caps that are used to block unused vacuum lines to stop the fluid from leaking out.
BTW: I'm curious about the suggestion of using 140W oil to help quiet the locker. I have a detroit and it's noisy when coasting. Anyone else experience this?
InternetRoadkill is offline
Old 12-12-2008, 07:01 AM   #10 (permalink)
jason191918's Avatar
jason freudigmann
Send a message via ICQ to jason191918 Send a message via AIM to jason191918 Send a message via MSN to jason191918 Send a message via Yahoo to jason191918
[*]Undo the brake line where it enters the back of the backing plate (not sure what exactly its called, please correct me if you do).
Brake cylinder?
__________________
JASON
1992 Pickup V6, 4x4, 5 speed, SR5, 300,000 miles young, every option except automatic tranny
31x10.5R15 | K&N FIPK | Cherry Bomb | 3" BL | 4 110W KC Light Bar | 6'6" Western Plow | 800W 10" Sony | 850W Sound Storm | 2 4" Obcon | 4 1" Rockford Fosgate Tweeters | 2 High Pass Crossovers | 2 High-Low Pass Crossovers | 2 6.5" Rockford Fosgate | Pioneer 4x50W Head Unit | Mechanical Oil Pressure Gage | Lack of EGR | Blinker Mod
Quote:
Originally Posted by Elvota View Post
Jason is right.
Quote:
Originally Posted by fishon1213 View Post
Jason rocks!!! :banger:
jason191918 is offline
Old 12-12-2008, 08:54 AM   #11 (permalink)
Threadstarter [OP]
Matt16's Avatar
Quote:
Originally Posted by jason191918 View Post
Brake cylinder?
I meant the round backing plate for the drum brake. Yes it goes to the wheel cylinder, but visually it goes into that round bit.
__________________
Matt16 is offline
Old 12-12-2008, 08:58 AM   #12 (permalink)
Threadstarter [OP]
Matt16's Avatar
I can only hear my Aussie when coasting around tight corners. I wouldn't call it loud though.
__________________
Matt16 is offline
Old 12-18-2008, 12:21 AM   #13 (permalink)
Threadstarter [OP]
Matt16's Avatar
To the mods: I added a second part- installing a locker- could you change the title to reflect that please? Thanks.
See original post for locker install instructions.
__________________
Matt16 is offline
Old 12-18-2008, 08:35 AM   #14 (permalink)
MKW
Good write-up! I have a question...in the pictures that you and SR5 posted, the middle part of the third(where the locker/spider gears go) looks different. Yours has a big hole to slide in the locker and his only has 4 little hole that you can look in and see the spider gears. What is the difference?? Mine is like the one that SR5 posted.
Please, forgive the ignorance.
Mike
MKW is offline
Old 12-18-2008, 09:18 AM   #15 (permalink)
Alex 400's Avatar
Mike
The trucks and 4runners came with different rear differentials depending on if you got the v-6 or the 4 banger. Matt16 has a 4 banger diff, while SR5 has the v-6 diff. the v-6 diff comes apart right down the middle to install the locker and then bolts back together. the actual carrier is stronger too.
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6, 5-speed, 31/10.50-15 Toyo A/T, All Pro 1.5" coil springs, Bilstein front shocks, doetsch tech mv12's rears, MC heavy duty clutch, 2.25" exhaust/50 series Flowmaster 183,xxx miles
Quote:
Originally Posted by slisdexia View Post
I blame the automatic transmission for the wussification of America
Quote:
Originally Posted by toyminator2000 View Post
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE
Alex 400 is offline
Old 12-18-2008, 09:38 AM   #16 (permalink)
MKW
10-4 thanks.
Mike
MKW is offline
Old 12-18-2008, 12:35 PM   #17 (permalink)
Threadstarter [OP]
Matt16's Avatar
4 Cyl diff with two spider gears:
On the left is a V6/ turbo diff with 4 spider gears.
__________________
Matt16 is offline
Old 12-18-2008, 01:31 PM   #18 (permalink)
ZUK
Personal Sales Rating: (1)
ZUK's Avatar
BIG 10-4! on using the rubber vacuum caps....I do that all the time....they work perfect for that application. As far as the locker being noisy during coast....that doesn't sound right. The only thing I can think of that could do that is different tire diameters....try a tire rotation and see what happens. It's also possible you have a sloppy driveline....pinion is a little loose and clunks back and forth and is aggravated by the near 1/4 turn of typical locker play. And yes, a heavier oil will quiet up the click-click noises from lunchbox lockers.
Matt16---You did such a nice job of 3rd member removal/Aussie install that when I get home in a couple hours I will add this thread to one of my Aussie install links. Your write-up will 'enhance' or give a breathe of fresh air to my Aussie install link. I might put your write up on this one shown near the bottom of this page....
http://aussielocker.com/install.php/TM7c35fd/f8a2/.html
ZUK
__________________
www.gearinstalls.com
2001 white Xtra-cab Taco 3.4L auto TRD
88 Runner/V6/auto/31"/5.29gears
Be always at war with your vices, at peace with your neighbors, and let each new year find you a better man. - Benjamin Franklin
ZUK is offline
Old 12-18-2008, 02:39 PM   #19 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Great write-up Matt!
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 255k |2.25" catback w/ magnaflow cat + flow 40 | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's and 700ffs |4" reverse lights| Grant GT |idler arm brace| E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 12-18-2008, 02:57 PM   #20 (permalink)
sa51's Avatar
great writeup, it will def help me out in the future
__________________
1999 toyota tacoma 2.7 xtracab.33x10.5 BFG mud terrains, 3" toytech coils,bilstein 5100s, nw offroad rear springs,trail gear front bumper.
Quote:
Originally Posted by the_ocho
so long story short. dont look at other yotas. it causes head gasket failure
Quote:
originally posted by a4runnerfreak
Hey SA.....just time for a new, younger, more improved model, thats all. 1 that is trainable. Just make sure she's of age......:D
TREAD LIGHTLY
sa51 is offline
Old 12-18-2008, 06:48 PM   #21 (permalink)
Threadstarter [OP]
Matt16's Avatar
ZUK
I got to thank you Zuk for your instructions, they were invaluable in figuring out how diffs are put together.
I should clarify that the locker makes noise when it coasts with the clutch in around a tight corner. Same noise as when you do the locker test to see if it is working. I'm sure its a normal noise, at least for those of us with 5 spds.
I think this is because of the inherent play in between inside couplers in the locker itself and the crosspin when there is no torque being transmitted from the driveshaft. In the absence of torque, the inside couples can move back and forth a bit and the ouside couplers can engage the inside coupler quick enough to make a click sound. When under power, the speed at which the teeth engage is dependent on wheel speed instead of the the force applied by the springs between the inside couplers. If you are lost, worry not, I would be amazed if anyone understood what I was thinking here.
Maybe this will help, should anyone wonder what I'm talking about:
__________________
Matt16 is offline
Old 12-18-2008, 07:59 PM   #22 (permalink)
ZUK
ZUK's Avatar
Ohhh....clicking around a corner is normal for both a 5 speed and auto. Get some of the synthetic 75W-140 and I bet it gets a little quieter.
The link has been updated.
ZUK
__________________
ZUK is offline
Old 12-18-2008, 08:01 PM   #23 (permalink)
Threadstarter [OP]
Matt16's Avatar
ZUK
I've got some 80W140 in there, the noise is so quiet that no one but me has ever noticed, except in a echo-y parking garage.
__________________
Matt16 is offline
Old 12-20-2008, 07:40 AM   #24 (permalink)
Yoda's Avatar
Done!
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
[SIGPIC][/SIGPIC]
Yoda is offline
Old 12-20-2008, 07:52 AM   #25 (permalink)
scuba's Avatar
bahh, finally...
Getting my aussie soon, this will help.
Thanks matt !!
__________________
SHUT UP AND WHEEL.
My 99 Tacoma Single Cab build.
Now representing All-Pro Off-Road. Call us for all your suspension and armor needs. 951-658-7077
scuba is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
9, aussie, differential, ford, grey, inch, install, locker, loosen, member, nuts, plug, removal, rtv, spider, tacoma, truck, ultra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Taurus fan Install writeup 3.0 V6 seafarinman 86-95 Trucks & 4Runners 86 03-22-2010 11:20 AM
Tranny Removal Writeup Bejiita 86-95 Trucks & 4Runners 45 03-08-2007 05:52 PM
WRITEUP: 3rd gen TJM 17 install Bob_98SR5 95.5-2004 Tacomas & 96-2002 4Runners 44 01-03-2006 04:30 AM
ATS A-arms install writeup? RobT2k 95.5-2004 Tacomas & 96-2002 4Runners 17 11-18-2003 07:08 AM
is there a writeup for SAW & OME install somewhere? 4FonZ 95.5-2004 Tacomas & 96-2002 4Runners 1 02-24-2003 12:02 PM
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
