Wreck my beloved 88 yota.. Pics
#50
#51
HAHAHA..your name is yota recovery..lol..kinda funny i think..cuz i pulled out a K5 that was burried to the frame..lol..and numerous 1/2 ton chevy's..and one big F150 about 50times...lmao..hes my wheelin buddy...he only had to pull me out once..and that was when the water killed my truck (battery got wet and blew a fuse..pulled truck out..replaced fuse..removed spark plugs..turn it a couple times..install plugs..fired right up...oh ya and it was about 15* outside..and sleeting..there was 4in thick ice on the water..rough times man rough times..lmao)
#52
well more progress is made.. at 3 in the mornin lol..
the hood dont fit good cause its bent bad, from where it flew up and hit my windshild.
so far i still need the side bumper brackets, one bumper bracket, and maybe a new hood
#55
should have done some mehcanical work whille ya had it apart. i know i would have replaed the front of the motor. Ya know like the timing belt, water pump, oil pump, gaskets... degressed engine and bay. Belts.... Pulleys.... anyhow nice job on repair its come out great. Ur going to need about 4 inches of lift Atleast to fit those tire though.... make sure all ur body grounds are back in place. should have gotten under there and painted the frame some too where its starting to surface rust... trust me its worth the trouble.
#56
#58
also i think i have landed my problem im not gettin fuell.. i just put 10 dollars in gas and all the truck has done since then is sit inn my yard and now its out of gas either someone stole my gass or i have a leak in my tank...
justdifferentials
14
06-11-2017 08:36 PM
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
09-09-2015 02:43 PM
