Worth going from V6 S12W calipers to S13W?
Hey guys, I tried searching for info comparing the S12W vs S13W calipers but I see most owners that switch to S14w's are coming from 4 cylinder calipers. I have an 89 4runner that has a leaky MC and Booster and thought if I was replacing those that it might be worth just switching everything over to a 2nd gen S13 setup.
My question to you guys is if you think the gains going from the S12 to the S13 is worth it. Budget isn't too much of an issue I just don't want to waste money on new calipers/rotors/pads if it isn't going to be a noticeable difference.
Thanks a lot!
Thanks a lot!
Thanks for the responses guys, from what I have read there isnt anything specifically showing it is worth the swap unless you needed to replace worn calipers and rotors anyways. Then in that case if you have then of course the s13w would be the choice... Im going to wait until then.
Jcrawl94
10
10-24-2015 04:34 PM
traxxi2003
52
06-29-2015 05:59 PM
MaK92-4RnR
7
04-04-2012 04:13 PM
Bawlzdeep
02-04-2012 05:05 AM
pattycakes77
05-23-2010 03:47 PM
