| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Winch with no power?
__________________
'86 Toyota 4Runner, 22RE, 5sp, 31" swampers, other than that - STOCK |
#2 (permalink) |
What size power wires are you running to it
__________________
www.stockardmaintenancesolution.com Leave the trail a cleaner place than it was before you got there |
#3 (permalink) |
i just installed my winch, i better go try it out before i get stuck like you did.
Your battery might be too weak for the size of winch you have. in the owners manual it tells you the minimum amount of cca (cold cranking amps)for your size winch. if your battery doesnt have however many cca's the winch book sais you need, that might be yer problem.
__________________
SAS 89,trussed, bobbed, Trail Gear front & rear 5''. 3.0 V6 cold air k&N, 40 ser. flowmaster, 5speed, HP ARB font diff, Marlin Crawler inner's and marfields. 5.29 yukons, Detroit rear, 35''x13.5 toyo's. Steadily growing body damage. Two way alarm, TG rock defense bumper, Warn 8000, TG crossmember,geard rive t-case w/marlin XD 4.7s. TG Sliders, some day dual cases and a cage |
#4 (permalink) |
I'm running standard size battery cables.
Also, when this happened the truck was running, and the volt meter dipped from about 14 volts to maybe 9-10 volts when the winch was running. Maybe I need a second battery or a bigger alternator? The winch is rebuilt.
__________________
#5 (permalink) |
Location: Vacaville/Sierra Nevada Mountains, CA/ UNLV (Las Vegas), NV
Are you running alot of aux. lighting or anything? A standard battery is not made to handle a winch. Yet alone a winch and aux. lighting.
__________________
'89 Beater Jeep Eater in progress 4.88's, TRD e-locker, Dual Cases, 33's, Armored, Tread Lightly Mixchallenge.info |
#6 (permalink) |
89 has a good point about the cca's. If you do have enough cca's, you might want to use welding leads, thats what I use when I hook up winches.
__________________
#7 (permalink) | |||
Quote:
May also be time to upgrade batteries.
__________________
Quote:
Quote:
------------------------------------------------------ 1991 Toyota 4Runner SR5 4x4, 3.0 V6, Auto, Alpine CDA-9807, 31x10.5's, 4.56's, 1" RB lift, 2" SDORI Coil spacers, Optima RedTop, Aisin manual hub conversion, and the all important FSM's |
#8 (permalink) |
I bought the winch second-hand, so I'm not sure of the age, but it looks quite new. I'm not sure it was rebuilt correctly, but it does function properly, it just doesn't seem to have the power that it should.
Sorry for the ignorance, but what's the big 3 mod?
__________________
#9 (permalink) |
how much cable did you have out? the 8000lb rating is only the last couple of cable wraps around the drum. were you revving it while winching or giving it gas trying to get out of the situation? a lot of times you have to be trying to get out to help the winchout, you can't just drag your ass out of every situation.
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. Last edited by crolison; 01-08-2009 at 08:35 PM. |
#10 (permalink) | ||
Search "big 3 mod".....it tells you 'bout upgrading the main power and ground wires. I don't remember them off the top of my head, at the moment.
__________________
Quote:
#11 (permalink) |
ya just search the, big 3 mod, there are threads all over about it, i read one yesterday.
__________________
#12 (permalink) | |
Quote:
I was revving it and trying to drive out in 4 low while using the remote inside the cab for the winch.
__________________
#13 (permalink) |
weak battery would be my guess. Your alternator doesn't put out enough juice to power a winch by itself, so your battery has to be in good shape and of high enough capacity to power your winch for any length of time. Having the truck running while you're winching helps to take some of the burden off your battery.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires. 2004 Camry LE - stock (and will stay that way) 1993 4Runner has been sold |
#14 (permalink) |
How old is your battery? It might be ready to go. Also, as others have said, size of the cables from the battery to the winch make a difference as well. You should be able to HANG your truck from an 8000 lb winch!
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap 3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/ |
#15 (permalink) |
My battery was a 650 CCA and I thought I was good to go for winching.
However it had a dead cell everything seemed fine until I ran the radio or the lights for about ten mins then the power would drop instantly then if I tried to start it needed a jump start. I'd test your battery and go from there. Honestly if you have a winch get a optima red or yellow top. Or at least a battery rated 800 CCA or higher. Replacing the old battery is pretty much the mod I do on most 4wd vehicles I buy. They are expensive but I think they are worth it in the long run. Like everyone said it's probably your battery.
__________________
86 Toyota 4 runner Soild front axle, 35x12.5 BFG KM2's, winch, blah blah blah.... http://www.yotatech.com/f116/my-new-red-snappah-152938/ My cardomain page Last edited by 934rnr; 01-09-2009 at 07:22 AM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| arb winch bumper,winch and adjustable coil overs | rugerm44 | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 11-27-2008 10:26 AM |
| hooking up winch power to optima batterie | weakyota91 | 86-95 Trucks & 4Runners | 29 | 09-27-2006 07:17 PM |
| Winch brushguard + winch fairinglead for 1stgen pickups TX $200 obo | dcg9381 | The Classifieds GraveYard | 1 | 06-29-2006 11:33 AM |
| In-Cab Winch Control in a 3rd Gen Toyota 4Runner Using an OEM Power Mirror Switch | Robinhood150 | Off Road Enhancements | 0 | 01-02-2006 06:43 PM |
| Hand Versus Power Winch | Denk | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 05-30-2003 03:15 PM |
