Wierd water pump leak? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-13-2007, 09:54 AM   #1 (permalink)
slosurfer's Avatar
I have a wierd coolant leak that I think I have traced back to the water pump. It doesn't seem to leak while I am driving, either that or what little is leaking is being burnt off, but I don't seem to lose any coolant while driving. It doesn't leak when it is cold, (ie nighttime, early morning), but if it is sitting in the driveway during the day it will start to slowly leak. It seems to be coming from behind the thermostat housing, but between the water pump and engine block. Where exactly are the weep holes on the water pump?
I am actually planning on doing the water pump/ timing belt soon anyways, but I thought this was weird and am not sure if it is the waterpump. Any suggestions? It is so hard to see in there.
Another ?, I want to do a coolant system flush. Should I do the flush right before I tear into the waterpump/ timing belt or should I flush it right after. I think it would be nice to have it flushed before and instead of refilling everything, do the waterpump, etc.. and refill after. Thoughts?
__________________
Chris
7th Annual Pismo Jamboree: Sept. 25-27, 2009
'93 4runner SR5 3.0 Auto 4WD
'07 Tacoma Dcab 4x4 TRD offroad
'89 F250 4x4 w/utility bed
M416 1/4 ton military trailer
"Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."
Ronald Reagan
Semper Fi
SLO 4wheelers
slosurfer is offline
Old 01-13-2007, 10:10 AM   #2 (permalink)
Targetnut's Avatar
Quote:
Actually it is not that wierd. waterpump leaks can be very finnicky as you have found. and a leak like that can go on for a long time or start dumping sometime later today.
Depends on how rancid your coolant is. if it is really nasty I'd flush it thoroughly before the waterpump.
__________________
Targetnut
don't talk about it, just do it!
Precision Import Service
'93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam,Megasquirt, 295cc injctrs, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate
Targetnut is offline
Old 01-13-2007, 10:55 AM   #3 (permalink)
4Crawler's Avatar
Weep hole is on the bottom of the housing where the pulley attaches to. Hole is there to let any coolant that leaks past the inner seal (and bushing) drip out so you know the seal is leaking. Coolant will wash any lube out of the inner bushing and it will not last long like that.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 01-13-2007, 06:27 PM   #4 (permalink)
slosurfer's Avatar
I can't tell if it is from the weep hole or from the gasket but either way I am going to do the wp/ timing belt. 103,000 miles and I am pretty sure it is the original for both.
It is time for a coolant flush also, the coolant looks fine, but I don't know the last time it was flushed so I think I will do the flush except for the final refill, then I will do the wp. That way when I am done with the wp/timing belt, I just have to refill and be done with it.
Since this isn't our DD anymore, I should be able to take my time and with the help of yotatech, do it right.
__________________
Chris
Ronald Reagan
Semper Fi
SLO 4wheelers
Old 03-31-2007, 09:55 PM   #5 (permalink)
006roadster's Avatar
Could be a hairline crack in the block; when it's hot the metal expands and seals the crack; when cold it starts to leak.
__________________
1988 Toyota 4runner 3VZ running 33x12.5 on 10" rims, Performance Accessories 3" body lift, daylighter 7" off-road lights, X-plode sound system
006roadster is offline
Old 03-31-2007, 11:04 PM   #6 (permalink)
slosurfer's Avatar
Ended up being the waterpump. Put a new one on 03/11, went to Death Valley the next weekend and jarred the heck out of the 4runner on the washboard roads, has been leak free since. I could see that it had been leaking out the weephole once I got down to the WP. I didn't know that the weephole is actually offset to the driverside and that is why it leaks out that way. I always thought the weephole was directly below, so I was confused why I wasn't seeing coolant there.
__________________
Chris
Ronald Reagan
Semper Fi
SLO 4wheelers
Old 04-02-2007, 09:11 PM   #7 (permalink)
Belive it or not I'm getting a similar leak; too weird. The leak only happens when the truck is sitting for a couple of days. When you said it leaked from the drivers side did you see the leak coming between the themostat housing and the crack pully?
__________________
Old 04-02-2007, 09:26 PM   #8 (permalink)
slosurfer's Avatar
not sure what the crack pully is, but the coolant was (looking at the front of the engine) to the left of the thermostat housing. At first I thought it was from the thermostat housing but then I could tell that it was coming from higher up, so that left either the wp or the wp gasket.
__________________
Chris
Ronald Reagan
Semper Fi
SLO 4wheelers
Old 04-02-2007, 09:34 PM   #9 (permalink)
slosurfer's Avatar
http://forum.ih8mud.com/showthread.php?t=146310
not mine, but the picture looks just like how mine did when it was leaking
__________________
Chris
Ronald Reagan
Semper Fi
SLO 4wheelers
Old 04-03-2007, 09:10 PM   #10 (permalink)
Thanks for the pitcture, that's exactly where the coolant is coming from. I guess I need to tear appart the front end. It's a little worrying the that timing belt runs the water pump. If the water pump fails so can the timing belt and the very quickly the engine.
__________________
Tags
4runner, leak, pump, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
leak from water pump gasket ,water pump dcmbsc 86-95 Trucks & 4Runners 10 08-06-2007 08:46 AM
antifreeze leak. I'm thinking the water pump... Charger92 86-95 Trucks & 4Runners 12 10-18-2006 02:48 PM
replaced 22r water pump, now oil leak FenderJazz 86-95 Trucks & 4Runners 7 06-05-2006 07:31 PM
93 4Runner Power Steering Pump and Water Pump/Thermostat Replacement Lucky_13 95.5-2004 Tacomas & 96-2002 4Runners 6 11-17-2005 09:37 AM
93 4Runner Power Steering Pump and Water Pump/Thermostat Replacement Lucky_13 Maintenance & Repair Archives 1 11-16-2005 04:26 PM
2009 InternetBrands, Inc.
