Why is my runner eating 5spds?
Old 07-17-2008, 06:00 PM
grayguy's Avatar
So, about 1.5 months ago I did a 3inch drivetrain lift on my 87' 4runner. It was fine for a while, then on the way home from my first wheeling trip with it, the tranny started whining in 5th gear. It got worse and worse, and eventually it sounded like a coffee can full of rocks in 2nd, 3rd, and 5th.
At this point I swapped the 5spd/t-case out of my 89' Pickup which never made a single noise. within 25 miles of driving with the "new tranny" 5th gear started whining again. I refilled the tranny with synchromesh and it's still doing the same thing...
Has anyone ever had a problem like this before?
Old 07-17-2008, 08:29 PM
Pistonman's Avatar
Is your driveline too long?
Old 07-17-2008, 08:39 PM
Staff
DeathCougar's Avatar
3" Drivetrain lift? What did you do about the bad driveline angle it created?
Old 07-17-2008, 08:45 PM
klr toy's Avatar
Just a thought... I can only assume that you disconnected the driveshafts while you did the work. Is there a possibility that the driveshaft separated at the splines and turned slightly? Have you noticed any unusual vibrations while moving? If the u-joints aren't in line with eachother on both ends of the driveshafts it can tear a tranny apart pretty quick. Even one spline difference could be enough. Just something to check... It definitely seems unusual to have the same issue in 2 different transmissions. You need to look for an external cause. Can you be more specific on what exactly you relocated?
Old 07-17-2008, 08:49 PM
TOYOTA 1's Avatar
yea but wouldnt the vibs just tear up the bearing on the output shaft on the t-case? and not hurt the tranny itself?
Old 07-17-2008, 08:50 PM
4Crawler's Avatar
A drive train lift won't necessarily make the drive shaft angles bad. It will steepen them a few degrees, but if you lift the drive train equally front and rear, the driveshaft alignment is preserved, assuming a stock rear shaft:
- http://www.4crawler.com/4x4/ForSale/MotorMount.shtml
I've run a 3" d/t lift for about 7-8 years now and have not gone through any transmissions yet.
Old 07-17-2008, 08:53 PM
Staff
yea, i thought about that after I posted. But if only the back of the tcase was lifted and not the engine itself, it can cause a steeper angle than just the 3 extra inches
Old 07-17-2008, 09:13 PM
klr toy's Avatar
Well You would almost think that the transfer case would let go first, but consider the massive size difference of those bearings. The tiny little needle bearing between the input shaft and output shaft can't take very much abuse compared to that great big bearing on the other end. Once there is any amount of flex between the output shaft and countershaft, synchros don't take long to shred themselves. Like I said just something to consider. We don't know if the engine was lifted as well which could definitely be a factor. Is there anything binding on the shift levers? What else has changed? Was the driveline stock to begin with?
Old 07-17-2008, 09:17 PM
klr toy's Avatar
But then again, it could just be a completely random coincidence....
Old 07-18-2008, 05:57 AM
Flash319's Avatar
The input bearings on Toy 5speeds don't last. I think it is just a fluke that they both went at the same time.
MTLroadierunner
07-15-2015 12:58 PM
cyclist231
07-07-2015 12:56 PM
musashi86
California SoCal
07-07-2015 03:31 AM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Why is my runner eating 5spds?
