When stepping on brake engine almost stalls.
Old 04-22-2010, 05:32 PM
DREDFIELD's Avatar
When i step on the brake the engine almost stall but wont. I disconnected the vacuum and the censor on the master cylinder and it still will do the same thing. Not sure what the problem is, Please Help.
Old 04-22-2010, 05:36 PM
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
Uh, auto or manual tranny? If manual are you steppin' on the clutch first, because hitting the brakes without hitting the clutch will def. cause a stall.
If auto, I couldn't even begin to hazard a guess as to what's wrong.
Old 04-22-2010, 05:45 PM
DREDFIELD's Avatar
Its a manual but thats not the case it is something to do with the power booster or power brakes. I can have it in neutral and hold the brake and it will almost stall.
Old 04-22-2010, 05:56 PM
kev
kev's Avatar
You probably have some vaccuum deficency.
Old 04-22-2010, 05:59 PM
DREDFIELD's Avatar
But i disconnected the vacuum hose and pluged it. It still almost stalled when i step on the brake.
Old 04-22-2010, 06:18 PM
yotaman85's Avatar
check to make sure your brake light wire or brake switch wire isn't grounding out somewhere.
Old 04-22-2010, 06:37 PM
mattaway's Avatar
Turn your idle down....
EDIT: Should be set to 750 rpm, if you don't have a tach, do it by ear.
Old 04-22-2010, 07:02 PM
DREDFIELD's Avatar
Ok thank you
Old 04-23-2010, 11:26 PM
mattaway's Avatar
Well... how'd it work out for you?
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
Johntom240
7
07-13-2015 12:18 AM
87turboPA
07-09-2015 05:58 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: When stepping on brake engine almost stalls.
