what's this noise? (video attached)
Old 08-31-2013, 10:53 AM
ridewrapper's Avatar
http://static.photobucket.com/player...psaa0a327b.mp4
What is making this noise?
Please turn volume up.
Old 08-31-2013, 11:03 AM
Cyberman's Avatar
It's a squeak.
Seriously, is it on that side? Try spraying some lube right between the axle and the backing plate to see if it goes away. Maybe a dry seal?
Old 08-31-2013, 11:06 AM
Yeah its just on the passenger side. I'm hoping its not a bearing
Old 08-31-2013, 11:48 AM
Cyberman's Avatar
If its a bearing, there should be some lateral play in the axle.
Old 08-31-2013, 12:00 PM
Teuf's Avatar
Bearing easy to do. Go for it.
Old 08-31-2013, 12:15 PM
Cyberman's Avatar
Well somewhat easy. If you do go for it, get new oil seals too.
Old 08-31-2013, 04:18 PM
Zero lateral play. I just move it a smidge and it squeaks. Must be just a squeak as cyberman said.
Its the rubber peice just behind the hub. I cleaned it off and lubed it up but no luck getting rid of the squeak.
Old 08-31-2013, 05:12 PM
Kiroshu's Avatar
Sounds like excessive seal friction. Unless the seal is damaged. Lube is your friend.
-Check differential fluid level.
Old 08-31-2013, 05:30 PM
I sprayed WD40 in there, didnt pull it apart. Just cleaned the dust and squeezed the WD40 tip ino the rubber and it still squeals. Maybe grease is better?
Old 08-31-2013, 05:53 PM
rworegon's Avatar
WD40 is a better degreaser than lubricant, IMO.
Old 08-31-2013, 05:59 PM
What is a better lubricant then?
Old 08-31-2013, 06:05 PM
rworegon's Avatar
Grease. Or, something like Tri-Flow.
Old 08-31-2013, 06:08 PM
Cyberman's Avatar
If you don't mind bleeding your brakes, you could pull the axle on that side and see if it still squeaks while its off the truck...
Old 08-31-2013, 06:27 PM
ksti's Avatar
^^^X2
Just pull the axle, it's not that hard and make sure your not gonna have a bigger problem in the future.
JNapolitano
11-14-2019 07:46 PM
Jcrawl94
10
10-24-2015 04:34 PM
Shaun Crystal Gomban
08-02-2015 08:00 PM
razorman8669
07-12-2015 12:13 PM
mlavery85
07-12-2015 10:33 AM
Quick Reply: what's this noise? (video attached)
