whats the best fuel additive?
Old 04-24-2010, 05:08 PM
YotANo0b's Avatar
Location: live in arizona at this time.. intending to move to minneso-rusty-ta... hope my bed holds up! :P
1988 4WD V6 5spd... i want to use a fuel additive to clean the injectors n what not.. are they all a gimmick? i asked at the auto store which ones best and they said sea foam or a Lucas product... thanks for the help!
Old 04-24-2010, 05:31 PM
myyota's Avatar
Sea Foam is the best in my opinion.
Old 04-24-2010, 05:36 PM
totally a bro
Staff
vital22re's Avatar
sea foam, and marvel... but the best thing to do is pull the injectors and have them cleaned and tested at an injector specialty shop.
Old 04-24-2010, 05:41 PM
Teuf's Avatar
no additive is the best one.
Old 04-24-2010, 05:45 PM
yotaman85's Avatar
seafoam FTW
Old 04-24-2010, 06:22 PM
moneyshot's Avatar
BG 44k. Hard to find, some dealers carry it. I've seen it work wonders!
Old 04-24-2010, 06:37 PM
pruney81's Avatar
I've used seafoam in the gas tank. I have friends and people on here as well will recommend using it in the intake.
Old 04-24-2010, 07:29 PM
Tracey98277's Avatar
i've never used sea foam but i've found that lucas does a good job at keeping the gunk out of the injectors and intake ports. i use it maybe once every 6 months.
Old 04-24-2010, 08:39 PM
Sponsor
Tofer's Avatar
Old 04-24-2010, 11:11 PM
CrazyEye's Avatar
Seafoam!
Old 04-24-2010, 11:47 PM
94toy4x4fever's Avatar
agree with every one on seafoam that stuff works well! Also lucus. But best thing like the other guys said pull em and have them rebuilt!
Old 04-24-2010, 11:59 PM
malteserunner's Avatar
I use Lucas.
On the other hand, I hear the NOS energy drink, pictured above, works wonders on GSXR engines....
Old 04-25-2010, 05:54 AM
Blue_petersen77's Avatar
Seafoam.... in everything
Old 04-25-2010, 06:46 AM
sportbiker929's Avatar
+1. works good
Old 04-25-2010, 07:11 AM
Levis Pennae's Avatar
Yet another for Seafoam in everything, however you should plan on changing your oil and filter soon afterwords.
@Tofer: I love you.
Old 04-25-2010, 08:03 AM
davo247d's Avatar
Originally Posted by Tofer
smart haha jk
Old 04-25-2010, 02:40 PM
Myron's Avatar
seafoam is the best Ive used. Half can in crank half in engine with a full tank gas..then oil change as soon as you empty...you will notice the difference.
Old 04-25-2010, 06:27 PM
tc
tc's Avatar
Either Seafoam or Lucas really smooth out the idle on my 3.0. Seems to run quieter (like less exhaust noise) too.
Old 04-25-2010, 07:28 PM
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
I've been pouring some off the shelf carb cleaner additive into my tank, but that's because I was having some hard starting in the winter that I ended up taking care of with some carb cleaner spray on a gummed up throttle. Haven't really finished the present tank of gas off yet, but it has been running a little nicer as the tank's gone on (somehow it's kept the gas from going bad over several months). Really I think I just need to rebuild my carb and change the fuel filter, but I'm lazy and have other things to take care of first and this helped do the trick. Don't know if it'd be okay using the same stuff in an EFI equipped vehicle, but I'd probably avoid it just because it's meant for carbs and not injectors (last thing I want to do is give someone advice that fouls those stupid little needle valves).
Old 04-26-2010, 12:15 AM
awdjunkies's Avatar
@Tofer: I love you.
+1 as well as plugs (In addition to the oil/filter).
Quick Reply: whats the best fuel additive?
