whats behind a 22re cylinder head?
Hi i wanna know what runs behind the cover plate behind the head i think its held down by 6 bolts? Its cause i have a leak drips from the top of the bellhousing and to the bottom of the transmission I just replaced my valve cover gasket and those half moon seals that go in the head. so i wanna knnow if oil runs through that cover plate or what? thanks
Sure its coming from the top of tranny? Have you taken a flashlight while the engines running and looked back there? I've never seen a 22r leak from that back plate....like never..... sure its not ur valve cover? Might be a rear main going out.... check ur oil pan....
checked my oil pan already no leaks dry as a desert. it might be my valve cover gasket maybe not sure. and you said that it might be the top of the bellhousing?
its that half moon seal directly above that EGR plate they like to leak throw a small bead of rtv on the rubber seal in the half moon area shoudl be good to go
Yea i'd say start small replaced valve cover gasket and have circle seals at the front and rear of head. RTV them like toyota requires which is ALL OVER.... usually.... but um yea.
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
