What is this wire go to? (Ground Wire Plug)
Old 10-10-2010, 07:35 PM
scubasteve's Avatar
There are two wires in my hand. The black wire is the ground wire from the engine block, it will be attached to the neg battery terminal. The other wire, with the plug....is the one I am curious about. It is attached to the same ground wire at the engine block and runs next to it all the way up to the battery. I cannot figure out what it might plug into, there is nothing in that area available for it to plug up with. Any ideas?
Old 10-10-2010, 07:38 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Wonder if it's the washer pump motor?
That's the only weather connector I know of that's on that side of the truck and towards the front.
Old 10-10-2010, 08:48 PM
VANCE164's Avatar
The wire to my washer fluid pump isn't tied into the block negative the only ones that are with it on mine are to the starter and another plugs into the intake pendlum.
Old 10-11-2010, 06:55 AM
scubasteve's Avatar
HA! Just noticed that my grammer rocks! That's a good indication of the state of my brain after a day of wrenching.
Both of those make sense....After a cup of coffee, I'm gonna check on it.
Old 10-11-2010, 07:04 AM
92 TOY's Avatar
do you have air conditioning?
that kinda looks like the wire to my compressor.
Old 10-11-2010, 07:43 AM
VANCE164's Avatar
^^^ thats also what I was thinking but dont have a/c in my truck so not sure
Old 10-11-2010, 07:47 AM
92 TOY's Avatar
that's a terrible picture, I'm sure I can get a better one.
but the point is, if you don't have A/C, that plug goes to nothing.
Old 10-11-2010, 04:06 PM
scubasteve's Avatar
No, A/C wire is already spoken for.
After another day of chasing the electrical gremlins around, was not able to find a home for this plug. I'll track it down eventually.
Old 10-11-2010, 04:11 PM
92 TOY's Avatar
sorry man.....i will look tomorrow in the daylight. getting a heck of a storm right now...not going outside.
the1998sr5
15
07-14-2020 08:35 PM
Doug4320
03-24-2018 10:11 PM
montanatruck
02-26-2017 07:07 AM
v_man
07-23-2015 04:01 PM
msane99
07-17-2015 10:13 AM
Quick Reply: What is this wire go to? (Ground Wire Plug)
