What type of Gas do you use?
Old 09-15-2006, 08:54 AM
cackalak han's Avatar
I run 85 regular...and I've got a supercharger! I don't go WOT too often, but when I do, I don't notice any pinging. And I don't care if she blows--I want to do a rebuild, anyway.
Old 09-15-2006, 08:57 AM
04 Rocko Taco's Avatar
Originally Posted by ovrrdrive
I don't care what John J. Chevron says, in an engine that's pinging like hell on cheap (lower octane) fuel there is a definite need to run higher octane. Octane is, simply put, a measure of a fuel's resistance to predetonation.
If you're getting spark knock or pinging, raising the octane is usually an easy fix.
Since it was brand new my truck has pinged on anything less than 91. Rather than make Toyota rewrite the owners manual, I have just always run premium.
Right now I have other issues that are making it ping even worse, and I am still running premium to offset some of that.
I'm not going to put my timing at 0 degrees to stop the knock and have ants run along beside my truck on the freeway...
It's kind of ridiculous for someone who's truck runs fine on 87 to say that it's a waste of money to run premium in a truck that doesn't run fine on low octane fuel. Is it that hard to believe that different situations require different solutions?
I mean in a normal situation. There is no gain to be had in a non pinging motor by using anything other than 87 octane. If your pinging of course, its an entirely different sotry, I didnt mean to offend.
Old 09-15-2006, 10:01 AM
rollem's Avatar
I think the point is made!!!
Old 09-15-2006, 10:17 AM
Yota82's Avatar
Originally Posted by 94toyota4x4
Well, In our trucks unless there supercharged theres no reason for running a high octane fuell, unless you have a full blown out racer 22re, the compression in the 22re is low enough so we can run the cheap stuff, most cars are like this, you can but high octane but youre just being stupid paying more for gas
Originally Posted by rdlsz24
I agree there's no reason to run higher than 87 unless your owner's manual calls for it (or if you have added forced induction).
Rob
You don't need to have forced induction to require a higher octane fuel. If your 22RE's timing is set at the stock setting with a stock engine, 87 will do just fine. But in cases of advanced timing for hp gains (it works) your engine is still stock but will now reguire a higher octane fuel. From my experence 8 degrees advanced will ping on 87 but not on 89. There is a very noticeable hp gain from just advancing timing and running a higher octane fuel.
Old 09-15-2006, 10:32 AM
  #25
gohawks's Avatar
87 octane 10% ethanol
Old 09-15-2006, 10:48 AM
  #26
jct61765's Avatar
87 octane from a name brand station.
Old 09-15-2006, 11:20 AM
  #27
Guardian_Saint's Avatar
On the 1992 4runner manuel it say 91 (premium ). I notice a diffrent from 87 to 91 and the compression on these 3vze are 170 psi each cylinder. Just don't use SHELL gasoline I don't know what they use in there gasoline, it cause a missfire or even hesitating when you press on the gas pedal.
Old 09-15-2006, 11:21 AM
  #28
rdharper's Avatar
Originally Posted by keithguts
OK, I have a 95 runner and would like to know what octaine you all are running. I have a 3.0 in my runner. Give me some feedback please. I guess what I'm trying to find out is what type is the best for a 3.0.
Keith
'94 3vze and '85 22rec. Usiing Chevron 87 or Costco 87.
Richard
skoti89
09-11-2015 07:46 AM
markf1
09-03-2015 01:23 AM
pyramid
07-30-2015 10:05 AM
daddio
07-18-2015 10:20 AM
Quick Reply: What type of Gas do you use?
