What sould I do?!?!?!?
Old Nov 8, 2007 | 03:17 PM
yoterBoater's Avatar
Red face What sould I do?!?!?!?
Last winter I put in a new motor in my 1993 pick up and ever since it gets hot ever once in a while and this week it hot super hot on my way home from a friends and it died the radiator hose blew on me. I went back to tow it home about a hour later and i tried to start it and it did after cranking it for a while but I pulled it home and i got the hose and check to see if there was any water in the cylinders by taking the plugs out and turing it over noting came out. i got it to start after cranking it and pumping the gas like crazy and i let it idle for about 10 mins and i atempted to drive it to test it out and it got hot again and now it got it home and it wont start. does anyone have any ideas what it might be please let me know.
Old Nov 8, 2007 | 03:20 PM
Jay351's Avatar
Sounds like there might be a blockage in your cooling system.
try burping the system by taking off the cap when the engine is cold and run it like that till its warm, also helps to park on a slight incline
Old Nov 8, 2007 | 04:08 PM
idea
ya i tried to do that and when i turned it i blew all over the place. would that keep it from starting tho?
Old Nov 8, 2007 | 04:53 PM
Jay351's Avatar
if it blew everywhere when the engine is COLD, that would point towards a blown headgasket.
Old Nov 8, 2007 | 05:07 PM
SEAIRESCUE's Avatar
Go to your parts store and purchase a cooling system pressure tester. Cheapest way I know, given your situation, to test for a bad head gasket or cracked head. You likely got one or the other if its pumping out water. Unscrew the oil fill cap and look for moisture and milky oil. Let us know what you find.
Old Nov 13, 2007 | 03:44 PM
Cool I Dont Know
would it blow every where if it was air locked. and i noticed that when i start it it clicks almost like its the timing chain is that possible.
Old Nov 13, 2007 | 03:59 PM
Tacoma750's Avatar
sounds like a head gasket..and if it isnt the headgasket, well its gonna be if you keep running it hot
MackMan83
Aug 19, 2013 05:53 PM
85celicagthatchback
Feb 7, 2013 10:07 AM
B-Fake
Aug 7, 2012 05:54 PM
tazzer
Jan 20, 2012 12:52 PM
