What is the second oil filter looking port on blocks driver side
Old 02-13-2011, 08:53 AM
mitfan311's Avatar
I have a 5spd manual 3.0. I see where the oil filter goes but there is some other port on the same side but further back. So
Something hooks up there but not on my model. I think mine is just leaking oil.
Old 02-13-2011, 08:54 AM
xxxtreme22r's Avatar
optional factory installed oil cooler.
Old 02-13-2011, 09:01 AM
mitfan311's Avatar
Is there a way I can block it off or just obtain the oil cooler part since it's leaking anyway.?
Old 02-13-2011, 09:16 AM
camo31_10.50's Avatar
junkyard, or you could just get the adapter from Toyota (can't remember the part number...or proper name for it right now) and run a second oil filter.
and NO you won't experience any problems with running two oil filters, except that your oil will get filtered twice.
Old 02-13-2011, 09:19 AM
or just get the gasket kit to replace what's leaking.
Old 02-13-2011, 09:27 AM
90301-68005 is the o-ring part number for under the cap
90430-20012 is the gasket part number between the bolt and the cap
15404-19013 is the union part number if you just want to add a filter to it and get rid of the whole cap assembly.
bigjstang
08-25-2021 12:41 AM
lledwod
08-30-2016 01:03 PM
Gamble_STi
07-07-2015 07:54 PM
MTLroadierunner
07-06-2015 12:17 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: What is the second oil filter looking port on blocks driver side
