What header should I get for my 22RE?
#81
yes, i feel your pain pruney, LCE seems to be very slow/delayed with their ceramic coating process, i haven't recieved my exhaust back yet. Also I do remmeber when i ordered my header and exhaust it took almost 2 weeks for John to ship my order out becuase it needed to be ceramic coated somewhere else, who knows?!
#82
It took me longer then that to get mine. From time of order to delivery was almost 5 weeks. But it was christmastime so I didn't want to bug em and be "that guy" so I patiently waited a couple weeks then checked in with them.
#84
He said they will be ready to ship around the 25th I believe. So that will give me some time to save up for the rest of the exhaust. Which will probably end up being a 2.25" magnaflow high flow cat and flowmaster 50 delta, and I 'll have the shop bend up some 2.25" pipes to connect it all up.
#85
Good choice pruney, that will sound good. Get some sound bytes when you get it all in.
#88
My LCE header and Pro Flow exhuast have been really fun this week (though I think a lot of the "race sound" is from my leak in the slip joint on the muffler
Definitely much better throttle response on my setup now though - even with my clogged CAT.
#89
LCE's header comes with a blockoff plate, so it's kind of a one size fits all application. There's o2 sensors in 2 different locations, and no o2 sensor on the carbed. Between the "sensor relocation kit" and the blockoff plate, they will send you the same header and it will fit.
And I think he was talking about all the pair and egr fittings on his rig (Cali emissions). You can pull it out, one guy I just helped passed emissions with his egr cut out and welded shut. There has to be some threads on it, I have read em. I just didn't have any of that junk in my rig to begin with.
#95
$280 for the helicoil? Holy crap! I got a kit from Tacoma screw for about $60 and did it myself. It was a pain, but 5 of the 8 needed attention. The pics look familiar. looks sweet, how's the loudness? I am getting used to it, plus it is making me get the dynamat done.
#96
The "Drone" is there at highway speed but that could be due to the small exhaust leak I have at the muffler slip joint (need to weld!). I'm getting used to it - the throttle response on overall high gear pulling power are a nice bonus!
#97
I picked up a Downey a few months ago, haven't installed it yet, but when I did my lookin' around I heard good things about it. They're out of business now though.
#98
Header studs
Do you guys recommend getting the header studs to avoid problems when installing the headers? Any ideas on how to avoid striping the threads? i always end up stripping threads...
thanks
thanks
#99
I got the exhaust stud kit from LCE when I got the header. They are a little longer then stock. Helicoiled the head. Torqued the header down to 33ftlbs. IIRC. Zero problems.
