What glue to use?
Old 03-16-2008, 11:23 PM
Matt16's Avatar
What glue to use?
I want to glue my rear bumpstops back in place. Not sure of the original factory configuration, but I think I will just scrape off the rust, and glue them in place. It isn't too crucial since I have determined that my shocks are too short to be jeopardized by over compressing the rear.
What glue would you use?
Old 03-17-2008, 01:53 AM
CyMoN's Avatar
Through The Roof it is a roof sealant that is great for gluing other things I glued a pair of work boots up 2 years ago and it came apart a month ago after using them for hiking boots for the last 6 months.
Old 03-17-2008, 02:45 AM
ovrrdrive's Avatar
I'm thinking completely remove rust and then rough it up with some 80 grit or less, clean with brake kleen, and JB Weld...
Old 03-17-2008, 03:23 AM
tampabayota's Avatar
what to use
use mighty putty , when the green turns white it will hold tight
Old 03-17-2008, 06:18 AM
MMA_Alex's Avatar
a decent quality epoxy...i havent had good results with JB Weld
Old 03-17-2008, 11:20 AM
Matt16's Avatar
I thought JB weld was for metals. What about sanding all the rust off, rust painting it and using marine epoxy?
Any other ideas?
Old 03-17-2008, 12:12 PM
leebee's Avatar
there is lepages construction adhesive that will stick anything to anything. clean both surfaces as best you can and have at it. youll have to figure out some way to keep a bit of pressure until this stuff sets up, usually 24 hrs.
lee
Old 03-17-2008, 01:20 PM
jmazoso's Avatar
Gorilla Glue
viesail
08-17-2015 08:39 PM
Robinhood150
08-19-2006 10:47 PM
Dublin
08-28-2005 03:20 PM
ilion
06-15-2004 02:43 PM
Quick Reply: What glue to use?
