What is that "dampner" on the throttle?
Old Oct 3, 2006 | 07:20 AM
wildman326's Avatar
I've got an 89 4x4 xt cab truck with 22re. I got a valve job and put the motor back together. Now it won't throttle down below 1500rpm - I fiddled with the timing. What makes it go down is when I push on the throttle and make that dampner go back to the bottom. Does the truck need that little dampner/shock looking thing?
The boot on it is cracked. I sprayed some wd40 on it, but that made it worse.
Old Oct 3, 2006 | 07:29 AM
snap-on's Avatar
you talking about the rubber intake "hose"?
Old Oct 3, 2006 | 07:53 AM
4Crawler's Avatar
That is the dashpot. It slows the throttle closing to prevent backfiring when changing gears. If the boot is cracked, remove it. I lube mine with silicone spray once a year or so (my boot is long gone):
- http://www.4crawler.com/4x4/CheapTri....shtml#Dashpot
Old Oct 3, 2006 | 08:05 AM
TNRabbit's Avatar
x2 on 4Crawler's post.
ALso, when you get the dashpot adjusted, you can adjust the idle with idle air adjustment screw.
Old Oct 3, 2006 | 09:48 AM
wildman326's Avatar
Thanks!
some drunk guy
Aug 3, 2021 06:09 PM
the_supernerd
Oct 1, 2015 09:20 PM
shredder4286
Oct 1, 2015 01:09 PM
Sam hain
19
Sep 30, 2015 08:25 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
