Weird squeal at startup..
Old 01-09-2009, 09:27 PM
874runnersr5's Avatar
Well, its starting to bother me now.. heres the run down
Nothing made noise besides my power steering when it was cold before i did my timing chain.
*after* i did my timing chain, i put a new alternator v belt in that i had..
now, at startup for the last couple months ive been getting this weird squeal..
sounds like a belt, but.. how can i test/verify that the belt is no good?
Could it be a alternator bearing? some type of bearing?
its just kinda embarrassing this squeal sound at startup and everyone looks at me...
anyone point me into some type of direction would be awesome..
Old 01-09-2009, 09:41 PM
tommy316's Avatar
Sounds like a loose belt. Make sure you dont have too much play in either the power steering belt or the alternator belt.
Old 01-09-2009, 09:42 PM
Tubbyfatty's Avatar
Yep, check yer belts.
Old 01-09-2009, 09:48 PM
PDX_1ton's Avatar
Probably your belt since you changed it. But do this just for fun. Next time you start the truck, push the clutch. If the sound changes or goes away.. Well you now know where it is around.
But most likly your belt
Old 01-10-2009, 07:48 AM
alright today ima check the belts, retighten everything and clean anything up..
Old 01-10-2009, 07:59 AM
Cyberman's Avatar
A little late, but if you spray each belt with WD40 while it's running, you'll find out which one it is. My power steering belt squealed like crazy for a while.
Old 01-10-2009, 08:06 AM
DanStew's Avatar
Check your water pump for leaks. I have the same squeal and i couldnt figure out what was making it. I was doing the alternator and noticed my pump weeping right on the crank pully. So at startup it would squeal for a second. Pisser is the water pump is brand new
Old 01-10-2009, 09:31 AM
hey cyberman, ive herd this trick before, how do i do so? Just spray each belt at the same time? or at different times? on the crank pulleys right?
danstew, i havent seen anything leaking from the wp area
Old 01-10-2009, 09:40 AM
NicCantDecide's Avatar
If you want to figure out which one it is, I'd suggest not spraying the crank pulley.
PS: spray the pulley at the powersteering pump...
alternator: spray the alternator pulley
A/C: spray the A/C pulley
Old 01-10-2009, 10:57 AM
ah i gotcha..
i dont think i have wd40!
lame..
Old 01-10-2009, 01:24 PM
LS1Steve's Avatar
I don't know if you want to use WD40.... that may silence it but could cause some slippage. Your local auto parts store should carry a can of belt dressing to quiet it down.
Old 01-10-2009, 01:42 PM
casey.eyman's Avatar
You can also use baking soda in a pinch to quiet a squealing belt.
Old 01-10-2009, 01:56 PM
but its only squealy at startup, doesnt matter if i ran it for 2 hours or 5 mins.
It just squeals up for a bit then shuts up... hmm....
Old 01-10-2009, 02:08 PM
bigt's Avatar
push the belt down a bit if it goes more then a little its too loose.tighten with nut.. they strech after a little bit
Old 01-10-2009, 02:21 PM
to be honest, i remember rushing the alternator belt crap because it was like 1am..
it was hard to get tension on it,hold the bolt on one side with a wrench and use a ratchet to tighten the bolt
Old 01-10-2009, 02:34 PM
bigt's Avatar
hrmm you just need one socket to make tension .. atleast on mine you do there is an adjuster nut...
Old 01-10-2009, 04:06 PM
il check tomorrow for sure, i need to flush my ps too.
i hope i got enough atf.
Old 01-10-2009, 06:40 PM
LS1Steve's Avatar
on startup it is cold. after a few seconds the friction heats and softens the rubber
Old 01-10-2009, 06:43 PM
yeah im aware of that, im was just trying to add more info.
Old 01-11-2009, 11:58 AM
fixed it!
so it was the alternator belt thing, i didnt think it was that loose but i tighten'd it up pretty good and started her and no noise!
yaya..
gave my ubolts for the rear leafs and everything else a good shot of pb buster to.
Quick Reply: Weird squeal at startup..
