weird idling problem
Old 04-05-2009, 08:17 AM
Ozkar's Avatar
Unhappy weird idling problem
Please help me, I have a 94 toyota 22re. Its been acting weird for a while. First my idle is high, when i start it in the morning it idles where it should, but as soon as it starts to warm up it goes up to about 1000-1200 range. Second, sometimes it will idle at about 1500-2000, but as soon as i hit the break it drops and fluctuates between 800-1200. before i would be able to adjust the idle, but i have no adjustment left. Anyone that can help me find the problem? Im in desperate need, cause it wont pass smog as is, and my registration is due. Thank you all.
Old 04-05-2009, 08:43 AM
chris1rb's Avatar
check your idle air control valve right under neath the front of the intake, i had the exact same problem and found out that was not working and had a bunch of gunk in it, cleaned it and the truck runs good now.
Old 04-05-2009, 06:23 PM
abecedarian's Avatar
Idle speed and timing are always set with the engine at normal / fully warm temp- 750 rpm / 5 BTDC for a 22re.
Saying it idles fine when cold, then goes bad when warm suggests the idle isn't set properly.
When cold, it can idle as high as 1500 rpm's, possibly higher, but as long as it settles to 750 when warm, that isn't an issue.
Old 04-08-2009, 02:55 PM
DupermanDave's Avatar
did you find a solution? did you fix the problem?
Old 04-08-2009, 07:48 PM
Ozkar's Avatar
Finally fixed it
Yeah just fixed it today, It was a clogged hose that fed into the idle air thing under the throtle body, ran fine today hopefully will run good tomorrow. Thanx to all for the advice.
Charecter1
11-06-2023 10:08 AM
Eggslinger
06-08-2019 03:32 PM
kyletbert
07-17-2015 11:39 AM
icentropy
07-14-2015 10:23 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: weird idling problem
