Weird Clucth Issue, Slips then Grips?
Old 12-13-2010, 06:04 AM
Shifty762's Avatar
I noticed the other day when shifting into third and accelerating I got some slippage. I was accelerating through third without issue and as I neared the end of third and was about to shift into fourth the engines RPM's climbed as if it was slipping. I backed off and floored it again and I got slipping again. When I moved into fouth I got no slipping. I have continued to drive and it has happened a few more times (2 times over 70 miles) but only in third gear, and maybe second (I don't remember). If I accelerate hard all the way through the gears I detect no slipping. It just happens randomly under normal driving conditions in my experience.
What could cause this?
Old 12-14-2010, 11:44 PM
gary96360's Avatar
Maybe oil is coming out of the rear main seal or tranny input seal getting oil on the clutch disc which causes it to slip
Old 12-14-2010, 11:47 PM
gary96360's Avatar
Oil then probably burns off disc when it slips and then it's back to normal for a little while. Maybe that's a possibility
Old 12-15-2010, 12:41 AM
sam333's Avatar
Clutch is worn out , it will slip more or less depending on the temp to the disc.
Old 12-15-2010, 12:50 AM
87 4x4's Avatar
worn out pressure plate is my guess. when it gets hot it slips more.
Ironmike4x4
02-03-2016 11:13 AM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
accuracy
08-04-2015 08:05 PM
yourrealdad
07-21-2015 11:13 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Weird Clucth Issue, Slips then Grips?
