Weird Brake problem
Old 10-01-2007, 07:55 AM
Lifelongtoy's Avatar
Question Weird Brake problem
Two things, not sure if they're related.
1. When I drive for the first time during a day my brakes squeal, but not while using them. In fact the squealing stops once I do use them.
2. Sometimes my brake pedal stiffens up, as if the booster was bad, to the point that the power brakes are gone. But if I give the pedal a good solid kick, everything returns to normal operation. This happens maybe once a day, I give it a good kick and it operates nice and smooth.
Don't know if they're related. Weirdin' me out.
Old 10-01-2007, 08:36 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Sounds like a caliper or calipers are seizing.
Old 10-01-2007, 09:05 AM
fillsrunner4's Avatar
check fluid level, you could also take the calipers off, check the pads, and get some caliper grease and grease up all moving parts that should help
Old 10-01-2007, 09:20 AM
Ringmaster's Avatar
Any freeplay on the rod between the brake pedal lever, and the booster?
It's a pain to see up under the dash, but it's gotta have some slack.
Old 10-01-2007, 12:08 PM
Not sure what you mean by free play in that area, but I'll check. Thanks
Old 10-01-2007, 03:46 PM
Ringmaster's Avatar
Just some slop/play in the rod.
Eggslinger
06-08-2019 03:32 PM
icentropy
07-14-2015 10:23 AM
Johntom240
7
07-13-2015 12:18 AM
jon.r
07-11-2015 03:34 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Weird Brake problem
