Warm Start Issue Still getting me...
Old 12-06-2012, 07:11 PM
quiggs12's Avatar
I have an 88 4x4 pickup 22re with MT. It starts EVERY time when it is cold. But if I leave it in the garage with a heater on it won't start unless I give it a shot of starting fluid (I know, not good for it). Also, if I run it for a while and shut it off it will start right up. But if I let it sit for 30 minutes or more then it wont start again without the help of starting fluid.
Now I do have an o2 sensor code that will come on and then turn off while I am driving it periodically. I ordered a replacement but am still waiting... But that wouldn't affect my start up would it? Other than this code and the stupid starting issue the truck runs awesome! No issues driving at all. There doesn't appear to be a high idle upon startup though... Thoughts? Thank you!
Old 12-06-2012, 07:49 PM
vikkz's Avatar
check your fuel pressure i had the same problem for about a year didnt think it was the fuel pump because it ran fine after it started. After i learned how to check the fuel pressure correctly to check if the pump would hold the pressure after the truck turned off i noticed that the fuel would drain back to the tank in 2-5 sec. Changed the fuel pump and now it works perfectly every time no more leaving me stranded at the store waiting for it to cool down.
Check the fuel pressure before the fuel filter to get an accurate pressure test. My truck had the fuel filter a little plugged that it would hold the pressure there.
Old 12-07-2012, 12:37 AM
91_TOYOTA_4x4's Avatar
What he said ^^^ check fuel pressure. Plus could also have a vapour lock.
Old 12-07-2012, 02:17 PM
quiggs12's Avatar
Fuel pressure is good. I actually even changed the pump about a month ago. I took the tank off my parts truck that I was stripping. That truck didn't have any issue starting. And even after the switch I still had the same issue...
Old 12-07-2012, 09:16 PM
94toy22re's Avatar
Check your valve clearances, mine where to tight and I was having a identical problem.
Old 12-08-2012, 05:39 AM
quiggs12's Avatar
Okay, I'll try that. I adjusted them early in the process of some of the work I have done on it. Therefore, I assume it is possible I was too aggressive in the adjustment... I'll let you know what I find. If there are any other opinions please advise. Thanks
Old 12-08-2012, 06:11 AM
MudHippy's Avatar
http://www.toyotapart.com/22R-E,_22R...T-EG011-89.pdf
Old 12-08-2012, 08:05 AM
quiggs12's Avatar
Interesting... Thanks for the info!
Old 12-14-2012, 12:19 PM
quiggs12's Avatar
I replaced the temp switch and still am unable to get it to fire after sitting post-run. I tried to start it and it wouldn't go. I then tried again in a minute or two and it fired right up... I am confused but don't want to just live with it like this. Keep in mind it fires right up if cold! Any additional info someone might have would be much appreciated. Thanks
Old 12-15-2012, 04:17 AM
quiggs12's Avatar
Mudhippy, any other ideas or thoughts? Thanks
Old 12-15-2012, 06:22 AM
MudHippy's Avatar
The Cold Start Injector Time Switch. Maybe you need to replace that too.
Also, the 22R-E engine mechanical troubleshooting section of the 93 FSM states:
Difficult to start; Hot engine
  1. Engine Coolant Temperature Sensor Circuit
  2. Fuel Quality
  3. Idle Air Control Valve
  4. Fuel Pressure Control System
  5. Intake Air Temperature Sensor Circuit
  6. Cold Start System
  7. Fuel Pressure Regulator
  8. A/C Signal Circuit
  9. Fuel Lines
  10. Injectors
  11. ECM
Old 12-15-2012, 06:42 AM
quiggs12's Avatar
1. Not sure
2. Fuel is brand new 89 octane
3. I changed this from the parts truck that didn't have this issue
4. Not sure
5. Not sure
6. Both injector and time switch changed
7. Changed
8. I don't have a/c???
9. Appear good
10. Have new seals but I guess that doesn't mean they aren't leaking. However, it doesn't appear to be a flooded start so what else could be a problem with these?
11. It doesn't appear to run correctly with my parts truck ECU? 5 months apart in manufacture date...
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
slider417
06-22-2015 10:18 AM
jmc88runner
06-18-2015 03:39 PM
Quick Reply: Warm Start Issue Still getting me...
