voltage light
Old 06-08-2014, 03:44 PM
skillbill's Avatar
voltage light
My volt light comes on and off . At the same time lights go dim to bright and a/c heat fan slows.This happens at idle and all speeds with lights on or off same with fan.My question is does my 91 22re 4x4 have a voltage regulator going out? This has been going on since I bought it 14 months ago. Thank for any help!
Old 06-08-2014, 04:05 PM
skillbill's Avatar
Does it have a voltage regulator outside of the alternator? Can I have another problem?
Old 06-09-2014, 12:05 AM
wyoming9's Avatar
Red face
No your voltage regulator is internal.
Could be a few things
could be old and tired wiring
battery terminals corroded
loose ground connections
poor connections in general
loose alternator belt
Old 06-09-2014, 01:28 AM
RAD4Runner's Avatar
By voltage light, you mean "Charge" Light?
Concur.
Take some voltage checks. Charging system with voltage to look for explained here
AkitaDog
09-01-2015 08:05 AM
JHalcyonM
08-04-2015 01:19 PM
msane99
07-17-2015 10:13 AM
Johntom240
7
07-13-2015 12:18 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: voltage light
