Viberation 93 4x4 v6
Old 11-02-2012, 05:57 PM
Bucholz24's Avatar
Im getting a viberation in 4th gear from about 2500rpms to 3000rpms. and if you let off the gas it will stop or push in the clutch it will stop. Would this be a problem in the transmission? I dont know what else it would be any suggestions?
Old 11-02-2012, 07:40 PM
ThatGuy1295's Avatar
Did the vib start right when you lifted it? Or just start one day?
Old 11-02-2012, 08:04 PM
dodge106's Avatar
i had a vibratoin in my 93 as well and it turned out that it was on the passenger side were the axle goes into the housing the bearing was bad. i havent fixed it yet but i put manual hubs on and it went away
Old 11-02-2012, 08:10 PM
you actually signed up to a yota forum as dodge106?
Ok im turd 107. Hows that mopar crap workin out for ya??
HUh huh, if ya put manual hubs on it and it went away, wonder what it was clevis. Well you'll never be a detective.
Old 11-02-2012, 08:13 PM
dodge106's Avatar
i guess at least im not that guy and yes i did and yes i do have an 06 cummins diesel thanks for asking
Old 11-02-2012, 08:15 PM
Jesus.... really. Not even relevant. He has a specific vibration in 4th gear at a certain rpm.
Not a cv shaft bearing vibration that would only be speed specific.
Old 11-02-2012, 08:18 PM
dodge106's Avatar
well to let you know that is when i noticed it vibrating as well was around 3000 rpm in fourth gear guess it could be a speed thing with a bearing not sure just stating what was going on with my 93 trying to be helpful.
Old 11-02-2012, 08:21 PM
ya that would be good info to stick in your original post. huhu
heeeeeewww that dawg of mine,
welcome to yota tech friend
Old 11-02-2012, 08:25 PM
dodge106's Avatar
sorry shoulda put it in the first post but didnt mine would only vibrate at that rpm and i think it has something to do with the torque because it did stop when u let off the gas or put in the clutch you could also feel it in fifth as well but by the time you get in fifth the whole truck vibrates anyway
Old 11-02-2012, 08:26 PM
and no is either driveshaft or transmission related, to narrow it down for the OP. Got one myself, Im actually not sure which one it is in my 01 taco. Got a 5th gear vib only below 50mph and only in 5th gear. I do think its u-joints because if I remove my drive shaft then stick it back in it goes away for a couple days. So I replaced the trans side u-joint, then stuck the drive shaft back in. No vib for a couple days then back again. Definently not trans in my case, but your prob does sound similar to mine.
edit: unless your doing 55 in 4wd.
Old 11-03-2012, 06:33 AM
Bucholz24's Avatar
It just started a few days ago. Thanks for the input ill have to get underneith it tonight and see if I can find anything. I.hope its something simple
Old 11-03-2012, 04:16 PM
Carrier bearing is a good thing to check also. But u-joints and carrier bearings are all hard to check with the DS installed. Your better off removing the DS and wiggling u-joints checking for smoothness.
Old 11-07-2012, 09:43 AM
Bucholz24's Avatar
Did some lookin under the truck. And Its the rear u-joint in the drive line. It has a two peice drive line. Is the extra cabs with a one peice drive line? I would rather have a one peice drive line.
Old 11-07-2012, 10:08 AM
You can get them or have one made, But no toyota never made any.
Old 11-07-2012, 10:25 AM
Bucholz24's Avatar
I wonder if there any thats compadible with the yotas
Old 11-17-2012, 05:31 PM
Bucholz24's Avatar
update on this. I changed the u-joint today and took it for a drive. It rides super smooth now like a new 2012 yota
Old 11-17-2012, 07:30 PM
rokblok's Avatar
Yes they did make one piece shafts for x-cab trucks...
mussy01
12-13-2016 08:20 PM
redneck17
08-05-2015 10:03 AM
defrag4
07-31-2015 10:50 AM
PopsDad1
07-30-2015 02:21 PM
pyramid
07-29-2015 06:53 AM
Quick Reply: Viberation 93 4x4 v6
