YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-22-2008, 09:09 AM   #1 (permalink)
InternetRoadkill's Avatar
Question VAFM restriction. real or imagined?
Has anyone actually put a vacuum gauge on the on the intake plenum and measured the manifold vacuum at WOT during acceleration to see if the intake system really is as restrictive as folklore believes? I'm really curious about this. I would do it, but my vacuum gauge is kaput.
The reason I'm asking is that it looks like it would be possible to fit a modern high-flow MAF to our 22REs and remove the VAFM without having to change the EFI system out. But if the VAFM isn't the problem that everyone thinks it is, there's no point pursuing it.
InternetRoadkill is offline
Sponsored Links
To remove this ad, register today!
Old 07-22-2008, 01:07 PM   #2 (permalink)
Flash319's Avatar
2 valves per cylinder is the problem, not the intake. Even if the intake is causing a bit of a problem, you are not going to get much by fixing it if any. 22RE's flow like poop. They are truck engines after all.
__________________
89 Extra cab, 22RE not pretty but it gets me there. 420,000 km
95 VW Diesel Extra Cab Toyota, not done yet(edit: DONE!!!).....
http://www.yotatech.com/f116/vw-diesel-build-up-135203/
92 Runner, Bone stock 415,000km
WANTED: Rust free 89-95 extra cab any condition
Flash319 is offline
Old 07-22-2008, 01:10 PM   #3 (permalink)
4Crawler's Avatar
My vacuum gauge easily drops to 0" Hg under wide open throttle acceleration. I do have a 3mm over bored throttle body.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-23-2008, 10:13 PM   #4 (permalink)
X-Tool Pimp's Avatar
MOD EDIT: (Lysmachia) BANNED!
X-Tool Pimp is offline
Old 07-24-2008, 06:55 AM   #5 (permalink)
Swansen's Avatar
Send a message via AIM to Swansen Send a message via Yahoo to Swansen
Quote:
HAHAHAHA, thats good time, but yeah, the VAFM inlet is about the size of a pencil, and i don't really care, you just can't pull that much air through that like one square inch area.
Swansen is offline
Old 07-24-2008, 08:19 AM   #6 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
just put a supra afm on it, it will open it up. remember its a truck engine, i dont care what you do to it, its not gonna be anywhere near a ferarri
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22RE 258,000 miles on original motor
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 07-24-2008, 06:47 PM   #7 (permalink)
Flash319's Avatar
Toyota Engineers are not stupid like GM and Ford. I would trust that the intake is designed properly for the engine. Unless you modify something (bore size, turbo ect) I think you are pis$ing into the wind.....
you know what happens when you do that don't you? Don't ask me how I know.......
__________________
Flash319 is offline
Old 07-24-2008, 09:55 PM   #8 (permalink)
The VAFM was borderline obsolete when it was introduced. It's a klunky solution to metering air into an engine. I don't know of any modern EFI system that still uses one.
The fun part is that I found my old MCU development tools and I still have a couple of prototyping units laying around looking for something to do, so the converter part is covered. I just need to write a program for it and make a wiring harness.
I also dug up a spare VAFM I had and hooked it to my shop vac. Surprise! The shop vac can pull it to near 80% open which means I can calibrate the MAF to the VAFM using the shop vac instead of trying to do it on a vehicle.
Old 07-25-2008, 04:01 PM   #9 (permalink)
corax's Avatar
if you are going to do all that work, you could just run a HKS VPC (Vane Pressure Converter). It's programmable and converts to a Speed Density System - no VAFM, no MAF. They're not made by HKS anymore, so you'd have to find one used.
__________________
'88 4runner SR5 - 3.0 7MGE eng swap - Marlin HD W56 - 4.56 V6 Thirds - '82 Toyota Celica Supra LSD up front - 32"x11.5" BFG AT KO's - NWMP Aux Gas Tank - home fab front and rear bumpers - Hannemann fenders
"Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
corax is offline
Old 07-25-2008, 04:13 PM   #10 (permalink)
abecedarian's Avatar
and besides, I'd be more worried about that plastic, behind-the-radiator crossover tube than the AFM
__________________
Quote:
Originally Posted by Obama 'Ironman' Hussein
I want to ensure that everyone has the same capabilities off-road. Whether from the factory through high-dollar investments, from the aftermarket or by the hard work of the American backyard mechanic.
Therefore, I am taking some suspension travel from the more capable, more invested, more costly vehicles and transferring ... no ... redistributing that suspension travel to the other less fortunate vehicles. I am doing so in order to guarantee that everyone has the same opportunities off road.
abecedarian is offline
Old 07-25-2008, 05:37 PM   #11 (permalink)
Swansen's Avatar
Quote:
little random?? just sayin
Swansen is offline
Old 07-25-2008, 05:44 PM   #12 (permalink)
Quote:
that's me- random. just when everyone is going in one direction, I fork off and go another.
__________________
Old 07-25-2008, 05:49 PM   #13 (permalink)
Swansen's Avatar
yes, i think that is apparent
Swansen is offline
Old 07-25-2008, 05:52 PM   #14 (permalink)
You guys have no sense of adventure or curiosity. No guts, no glory.
FWIW, I already have the code for the converter half written. The only thing I'm really missing now is to take a trip to the junkyard and pick up a used MAF and its pigtail. Total expenses so far: $0.00. Can't go wrong with that.
To be honest, I don't really care if it does anything magical or not. It's just an excuse to play with the FI to see what happens.
Old 07-25-2008, 06:30 PM   #15 (permalink)
Conversion from AFM sensors to MAF and MAP sensors has already been done. There actually is little to no reason to do so since the more accurate sensors offer little advantage over the factory afm sensor other than for accomodating turbo/supercharging applications up to the capabilities of the ECU, for which the AFM can already suffice. Above which, an aftermarket fuel management solution has usually already been implemented.
__________________
Old 07-25-2008, 06:44 PM   #16 (permalink)
Swansen's Avatar
Yeah, and are completely ridiculous, seriously.
Swansen is offline
Old 07-25-2008, 07:39 PM   #17 (permalink)
Targetnut's Avatar
first you need to understand that the stock head only flows about 130cfm.
Even then you'll likely find some pressure drop, and it might even go 1"hg (13.5"H2O/1/2psi) or so which will reduce peak power some, but really It's likely not to make a difference you can feel.
Now if you port the head, go with a bigger cam, and bump up the compression, You'll be increasing the flow potential and that restriction will create a bigger pressure drop and be more of a factor.
I was thinking about using a MAF, but electrically they work very different from an AFM and it was just looking to complicated. But I'm no electronic guru either.
Now I'm working on a Megasquirt. this will use a MAP sensor and eliminate any measurement device in the intake tract
__________________
Targetnut
don't talk about it, just do it!
Precision Import Service
'93 2WD 22RE, Ported w/os valves, custom intake manifold, crane cam, 295cc injctrs, Supra AFM, Supra fuel pump, adj fuel pres reg, 70mm throttle, LCE header, V6 Taco cat, 14lb flywheel, Kevlar clutch, W58 and short shifter, 4.10 gears w/Truetrac, drop spindles and blocks, 245/50-16 Yokos on 16x8 wheels, 4WD fenders, bumper, and valence, skinned tailgate
Targetnut is offline
Old 07-25-2008, 08:31 PM   #18 (permalink)
how so, if I may ask?
__________________
Old 07-26-2008, 08:12 AM   #19 (permalink)
Swansen's Avatar
I'm not exactly sure about what you were thinking, but these are not exactly options.
http://www.yotatech.com/f116/mass-ai...sensor-115962/
http://www.yotatech.com/f116/maf-bypass-106148/
Swansen is offline
Old 07-27-2008, 02:58 PM   #
