Vacuum Line Question
Old 04-11-2015, 02:33 PM
mkultra's Avatar
I'm not sure what this vacuum attachment is (see pic and insert in pic) but it has 3 connections. The top middle connection has a plug in it and when I first looked at it the far hose was attached to the end of the plug on the middle connector and the far connector had no hose on it. I guessed that the hose needed to come off the end of the plug and go on the connector as that seemed to make sense but I'm trying to make sure and the connector with no hose definitely didn't seem right. It's a 94 22re w auto, air and cruise. Thanks!
Old 04-11-2015, 03:13 PM
grumpin's Avatar
I have a 1987 with a 22RE and mine has two caps and the hose goes to the VSV.
Sorry, it doesn't show the VSV.
This old photo shows it. Its the greenish VSV, towards the rear of the engine.
Old 04-15-2015, 07:00 PM
noahstancik's Avatar
It's for the EGR, just emissions control. I pulled the EGR out of mine and capped everything off that was connected to it.
Old 04-15-2015, 08:54 PM
scope103's Avatar
The short device with 3 ports is the "gas filter." It supplies manifold vacuum to components that need it, like the PAIR valve (through the VSV), cruise control, ADD, A/C Idle-up, and Fuel pressure idle-up. http://personal.utulsa.edu/~nathan-b...14layoutan.pdf All three ports are the same.
The "gas filter" does NOT connect to the EGR. http://personal.utulsa.edu/~nathan-b...18egrsyste.pdf
smthwsn357
12-04-2023 02:08 AM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
jgwerth
07-16-2015 03:23 PM
TokyoD23
07-12-2015 06:01 AM
Quick Reply: Vacuum Line Question
